August 9, 20187 yr Longer story but short is that I blew my engine on my 2009 Forrester and it needs to be replaced. I have a friend who has a wrecked 2003 Forrester and I have that engine that was pulled with everything attached in case it was needed. It was running well when pulled out last weekend. However, I can't get a straight answer if that older engine will fit in my 2009 vehicle? Anyone know these things inside and out and can let me know. The 2003 VIN #JF1SG656X3H764762 2009 VIN# JF2SH64669H765037 Heard that the engine model went from a 'xxxxxxG' in the 2003 to a 'xxxxxH' model designation in the 2009 or something like that so I'm hoping it's a minor change. I was told that the 2003 would definitely drop right into up to a 2008 but is questionable into a 2009. Not sure if that's convenient BS from the mechanic who wants to sell me an engine with his markup added instead of installing what I have. I'm hoping somebody can explain the differences and give me a definative answer.
August 9, 20187 yr Hi, welcome to site. More searching here and online will get you an answer. But the short answer is No. Not 'drop in'. 2006+ had i-AVLS on the heads, so that means a no to. Also the wiring is different. And the intake manifold due to an older style...but technically it'll bolt up. I'd guess the shortblock might work, but I also just read on here that the 2009+ blocks may be different enough to cause issues. Best option is find 2009+ EJ2.5 - watch out for the PZEV versions as they're also different. And it depends on how much of the engine is toast - just the shortblock? Or the heads too. Remember the HG issue..any USED engine is susceptible.
August 9, 20187 yr Author Thanks. Kind of figured that. Whatever I find I will have them replace the timing belt/water pump/head gasket before they drop it in.
August 10, 20187 yr Sandy, I think we have met and talked a few times, if you are the same Sandy that lives in the Greenbriar subdivision. I am Larry, the guy that walks the two yorkies in the neighborhood. Drop me a PM, I have some ideas, as I had an engine swap done not that long ago.
August 10, 20187 yr Reman short block from Subaru. They are $2150 and come with a 3yr/36k warranty. Best deal going by far. The later model EJ's command a premium in the used market. You'll pay almost as much for a 100k used engine as a 0 mile short block from Subaru with a warranty that can't be beat. GD Edited August 10, 20187 yr by GeneralDisorder
