January 18, 20197 yr Does anyone know if this will fit my 4wd wagon? https://www.amazon.com/Walker-Exhaust-46681-Resonator-Assembly/dp/B0015KVCI8/ref=pd_ybh_a_4?_encoding=UTF8&psc=1&refRID=91WKZ0AMWQWY9FM6F5EB Walker 46681 Resonator Assembly Thanks in advance, Eric
January 18, 20197 yr IF it is a EA82 engine, that looks different than any I have had. Do they claim it is for your car? Normally, they have the inlet and outlet pipes in line with each other - that is, you could put a straight piece of pipe in place of the housing without moving anything. The one in the picture in the link the outlet pipe is offset to one side. On all of the EA82 style cars, that "resonator" is not a resonator, it is a second catalytic converter. That may or may not matter to you, depending on the laws in your area.
January 19, 20197 yr Author Thanks, and yes I saw the offset. I am not sure what the differences other than that would be. I'm not concerned at all regarding the cat converter, just looking for something I can make work.
January 19, 20197 yr According to my Walker catalog,that is the correct number.Picture is wrong though.
