Weberized ea81 stalls when turning left
I installed a new Spanish Webber on my 83 GL two years ago and it ran great for a while. But around 6 months ago it started stalling when I turn left with the clutch pushed in. I recently put in a fuel pressure reg when it started flooding but I am still having the same problem. Any help would be greatly appreciated.
Thanks.
The installation guide from Weber said it came set at the right level from the factory   But I suppose I should crack into it and check. Anything else I should look at while I got it split in half?
Check float buoyancy(no holes/fuel absorption) and alignment(no rubbing)
Inspect and clean the needle and seat.
Check the float drop while you are there.
Some floats need periodic adjustment.IME.
Edited by naru2
