April 13, 20196 yr Forgive me if this post seems a bit brusque, but, i have been searching for over a week for the answer to what i think is a simple question, with no luck. My question is, which of the 4 upstream O2 wires (2 blacks, one white, one blue) are for the heater circuit? The car is an 04 Impreza Outback Sport, 2.5, non-turbo, automatic. The reason for this is, i have a P0032 code, that, as soon as you clear it, then start the car, it comes right back, and, the car is due for inspection in 2 weeks, and wont pass with a CEL, so, before i spend $195 on a new OEM sensor, i want to make absolutely sure it is the sensor. Yes, i know i can get it a bit cheaper from Rockauto, and even cheaper from Amazon, but, i prefer dealer/OEM parts.
April 14, 20196 yr The factory sensor is made by Denso. There is no reason to buy it from Subaru. They didn't make it nor do they have a corner on the Denso sensor market. Black wires are heater element. White is sensor ground, blue is signal. GD Edited April 14, 20196 yr by GeneralDisorder
April 14, 20196 yr Author 9 hours ago, GeneralDisorder said: The factory sensor is made by Denso. There is no reason to buy it from Subaru. They didn't make it nor do they have a corner on the Denso sensor market. Black wires are heater element. White is sensor ground, blue is signal. GD I already picked it up, i just haven't installed it yet. I planned on doing it today, until it started pouring out.
