May 1, 20196 yr Author Despite such an even keel ( floor is the same) I have eyebrow measures 10 mm lower on the drivers RHS ??
May 1, 20196 yr Talking to yourself again Jono?? Must be something I have to look forward to with the difference front to rear, maybe your front bumper isn’t mounted properly - or you’ve got a twisted body, but I’d expect to see that show up in the rear end too. Cheers Bennie
May 2, 20196 yr Ok this is not a smart as s comment but is the front 0.3 degrees level as well? 10mm is so small pump the tire up more, let some out the other side? Failing that bust out with a spacer or shim for the strut mount? Getting ready for an upcoming show? cheers man
