How good is this for even suspension ?
I will blame the concrete for that small discrepancy ;)
  • 2 weeks later...
Despite such an even keel ( floor is the same) I have eyebrow measures 10 mm lower on the drivers RHS ??
Talking to yourself again Jono?? Must be something I have to look forward to :P
with the difference front to rear, maybe your front bumper isn’t mounted properly - or you’ve got a twisted body, but I’d expect to see that show up in the rear end too.
Cheers
Bennie
Ok this is not a smart as s comment but is the front 0.3 degrees level as well?
10mm is so small pump the tire up more, let some out the other side? Failing that bust out with a spacer or shim for the strut mount?
Getting ready for an upcoming show?
cheers man
