Ej22user Posted May 19, 2019 Share Posted May 19, 2019 Howdy. New forum member here with a quick question. Me and my buddy are working on my 97 impreza 2.2 wagon. We're doing head gasket replacement. The thing blew due to low radiator levels. My buddy, who's a mechanic, doesn't have much experience with Subarus and commented on the amount of piston pin bushings on each cylinder head. There were 2 on each head. He said he believes there should be 6 on each. Does that sound right? We're thinking of replacing them and don't want to order more than necessary. Open to your input (There's a bunch of other stuff we're replacing on the vehicle but this my current curiosity.) Thanks! Quote Link to comment Share on other sites More sharing options...
FerGloyale Posted May 19, 2019 Share Posted May 19, 2019 Do you mean the hollow dowels around the top corner Head bolts? If so, 2 is fine. That is how they come from the factory. I have heard of high HP turbo builds using 4 or 6, but it isn't necessary for standard engines. 2 is how it's supposed to be. When I think of "piston pin" I am thinking of wrist pins. But those have nothing to do with the heads. Quote Link to comment Share on other sites More sharing options...
Ej22user Posted May 19, 2019 Author Share Posted May 19, 2019 38 minutes ago, FerGloyale said: Do you mean the hollow dowels around the top corner Head bolts? If so, 2 is fine. That is how they come from the factory. I have heard of high HP turbo builds using 4 or 6, but it isn't necessary for standard engines. 2 is how it's supposed to be. When I think of "piston pin" I am thinking of wrist pins. But those have nothing to do with the heads. Hey, thanks for the reply! These are what I'm referring to. https://www.rockauto.com/en/catalog/subaru,1997,impreza,2.2l+h4,1269053,engine,piston+pin+bushing,5632 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 19, 2019 Share Posted May 19, 2019 They are only used on the two top corners for head to block alignment. GD Quote Link to comment Share on other sites More sharing options...
Mike104 Posted May 20, 2019 Share Posted May 20, 2019 19 hours ago, Ej22user said: Hey, thanks for the reply! These are what I'm referring to. https://www.rockauto.com/en/catalog/subaru,1997,impreza,2.2l+h4,1269053,engine,piston+pin+bushing,5632 I think they are generally called locating dowels rather than piston pins. 1 Quote Link to comment Share on other sites More sharing options...
