August 18, 20196 yr Any reason why home made exhaust gaskets between head and exhaust flange won't be reliable? Sandwiched with a fine grade sealant I have a little 2 mm sheet sitting about and wondering if anyone has tried before, thinking about the heat treating, annealing? of copper sheet when used as head gaskets
August 18, 20196 yr I made up gaskets a while back. Posted on here. Layered fibreglass mesh with copper RTV. Details are in the other thread. They are still sealed up. They are reusable, made and cured off the car. Edited August 18, 20196 yr by DaveT
August 18, 20196 yr im still using my home made multi layer copper gaskets for intake and exhaust manifolds with permatex copper gasket dressing between layers there on there second motor now still holding Edited August 18, 20196 yr by ferp420
August 19, 20196 yr My old thread, with details on making exhaust gaskets. Lets see if this link will work.... -
August 19, 20196 yr my home made copper headgaskets failed i havent tryed the multlayer copper gaskets though im thinking 2 layers of copper ringed around the cylinders and silicone sealent around the water jackets should hold but why headgaskets are cheap and your not gona boost the hay out of a ea82 so there isent a need for a better stronger sealing head gaskets with 2 layers ringed there no compresion increse like a single layer gasket so no performance gains ether
