Oversized Pistons
What is a good set of oversized pistons and rings to get for an ej25d from a 1999 legacy? .020
Thanks
Will rings from a newer 2.5 work? Because its kind of difficult to find rings specific to the 97-99 ej25.
Ex. Rings for an sti or baja or something similar.
Edited by MWLoyale
NPR piston rings are the best "stock" rings for subies.
I would make sure to get the correct ones.  Ring thickness and width may be different on newer 2.5 (i believe they are, especially if turbo)
Not specifically endorsing this seller, but I found these in like 20 seconds of searching.
https://www.ebay.com/i/250743961661?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=250743961661&targetid=596465943828&device=c&mktype=pla&googleloc=9033024&poi=&campaignid=6470719340&mkgroupid=77931583832&rlsatarget=pla-596465943828&abcId=1140476&merchantid=6482944&gclid=EAIaIQobChMIoeGT7a3i5AIVkcVkCh1eCgRGEAQYASABEgKRc_D_BwE
Those would be the ones you want.
Thanks, i also found those earlier today while browsing. I saw that the sti rings are indeed a different thickness and wouldnt be compatible.
