November 2, 20196 yr When I fitted my strut spacers, I noticed that the bearings (Koyo 6302) on the front struts were ‘open’ (ie no shield on one side and fairly dry. I re-greased them, and reinstalled the strut assembly, pending a further strip down when I finally replace struts/spacers with Legacy outback struts The top-hats themselves look & feel fine, and barely any rust at all. Having checked prices of new top hats of decent quality, I opted for buying just the bearings, at considerably less cost. Now I am wondering if they are a simple press-out press-in job to replace. Anyone know? thanks Edited November 2, 20196 yr by Mitchy Photo
November 2, 20196 yr There's quite a bit of metal you'll need to remove to press them out. Once replaced you'll have to figure out how you want to secure them in- some of that metal might be able to be retained and peened back over I suppose.
November 3, 20196 yr Maybe bake it ? Electro-heat it ? Some freeze blast from a can on the bearing and hopefully it drops out and you tuck the new one in.
November 3, 20196 yr it is far easier to just replace the top hat - KYB makes these in addition to struts for Subarus and they are a great fit.
November 3, 20196 yr Author 3 hours ago, heartless said: it is far easier to just replace the top hat - KYB makes these in addition to struts for Subarus and they are a great fit. -without a doubt, but I hate tossing decent oem stuff away. The new strut I have are indeed KYB. Obviously it cannot be pressed out upwards ( as in my photo), -I can’t remember how the mounts look from underneath, can’t one just press the bearing out (ie: downwards in the photo)? Maybe someone a picture of a strut mount from below..... Mine are mounted on the car now. thanks
November 20, 20196 yr Metal retainer on the bottom. Lots of grinding and then you'd have to weld a retainer back in to keep the bearing from coming out. Pulled an 07 Forester struts off yesterday and checked.
November 22, 20196 yr Author On 11/20/2019 at 12:16 PM, lmdew said: Metal retainer on the bottom. Lots of grinding and then you'd have to weld a retainer back in to keep the bearing from coming out. Pulled an 07 Forester struts off yesterday and checked. Oh Balls tx
November 23, 20196 yr I'm sure they press the bearing in and then bond the top and bottom half with the rubber/or whatever material it is.
November 24, 20196 yr Author OK thanks , I’ll be pulling out the suspension soon as I now have the new struts sitting on the bench....
November 25, 20196 yr as long as the bearing moves smoothly, it will be fine for a while longer. if it is notchy, or grinding at all, the top hat should be replaced.
