November 29, 20196 yr I have had the red light on with the Airbag for a long time. No history of deployments with that. The state inspection passed; someone from NY wants to buy the 1996 Brighton, was a little concerned about the light. I think the fuses were checked and don't think I still have a problem one. Thanks for input on this.
November 30, 20196 yr Airbag light on means a fault in the system and the airbags won't deploy in a crash. Could be a crash sensor, control unit or an air bag. I was able to fix my 03 Forester by putting in a unit from a pull and pay. I do believe their is a method to pull the fault codes out but I don't recall how its done.
December 1, 20196 yr Author As far as I know it is not defective as the light went on, a long time ago without cause.
December 1, 20196 yr if the light is on, there is something in the system that is causing it. the light does not come on for no reason whatsoever. a bad sensor, bad wiring, damage to the control unit (moisture or something) - something caused the light to trip.
December 2, 20196 yr 22 hours ago, heartless said: if the light is on, there is something in the system that is causing it. the light does not come on for no reason whatsoever. a bad sensor, bad wiring, damage to the control unit (moisture or something) - something caused the light to trip. And if the Airbag light is ON the airbags WILL NOT deploy in an accident
December 3, 20196 yr Author This was definitely a mechanic's job; I dropped it off and he did the airbag and an exhaust leak, so hopefully the car will be ok for now as I have been trying to sell it. It is running too well to sell for only $1300 IMO.
December 4, 20196 yr That’s he one in New Canaan , right ? Man that thing won’t sell , and it’s crazy.
December 5, 20196 yr Author I had several offers at $900; some sellers assume as a Subaru the HGs are a ticking timebomb, but it is a 2.2. A couple guys are interested now at around the asking price.
December 21, 20196 yr Try unplugging and replugging the connector under the driver's seat a few times. It solved this problem on our '98 Legacy GT. Prior to doing that I was able to pull a fault code of 12 (the airbag ECU is more like an OBD1 where you need to jumper a wire between two pins in a connector under th edash and count the blinks of a light to get the code). The error code I pulled was very general and didn't identify what was wrong. I was told dealers may have an apparatus that can be hooked up to older Subaru's to figue it out. I'm glad it was only the coinnector in my case.
