1995 Subaru Legacy
Where is the fuel pump relay located ?....1995 Subaru Legacy
Way up above the fuse box under the dash.
Edited by Rampage
The RELAY is under the dashboard beside the main loom power relay.
The power wire to the fuel pump is usually a thick black/red stripe wire.
Cheers
Bennie
Not sure where you’re at with your diagnosis but I’d just like to say that if you’re tracing and can’t find what’s wrong go to the pump , and check the connector that feeds through the cover. Mine toasted out and I spent way too much time hunting the relay and all that.
Good luck.
6 hours ago, moosens said:
Mine toasted out
That reminds me, I found the plug inside the tank for that connector fried about a year ago on our 95 RHD. The Denso pumps have a pigtail with a plug on each end, one for the pump and one for that connector.
My wife was on her mail route she called and said she could not hear the fuel pump run. I grabbed my spare pump and a box of other stuff and tools and we swapped cars. Lucky I had some wire with. I wire nutted onto the pump wire inside the tank and hooked to a wire with a cigar lighter plug. Drove home and replaced it.
