March 6, 20206 yr is there a way to make the fog lights stay on when the high beams are selected? i dont want them to run without the headlights just want them to not shut off when i switch on brights. Edited March 6, 20206 yr by sirtokesalot
March 6, 20206 yr Author 3 hours ago, heartless said: other than completely rewiring, no i had thoght about that just build a little fused relayed off the low beams power source and wiring the fogs to that
March 6, 20206 yr not sure why you would want to do this, since the fogs would basically kill the distance vision of the high beams (which is why they are the way they are from factory) fogs are meant for use in poor visibility conditions, not general driving use. but to each their own i guess
March 6, 20206 yr 13 hours ago, heartless said: other than completely rewiring, no False There's a wire or 2 in the circuit running to the headlight switch so they only work with the low beams on. I've modified this on almost all my cars. sirtokesalot, if you'd care to enlighten us as to what you're working on, I'll answer your question. I normally will not even respond if I have to ask this. Edited March 6, 20206 yr by Numbchux
March 7, 20206 yr Author On 3/6/2020 at 6:13 AM, Numbchux said: False There's a wire or 2 in the circuit running to the headlight switch so they only work with the low beams on. I've modified this on almost all my cars. sirtokesalot, if you'd care to enlighten us as to what you're working on, I'll answer your question. I normally will not even respond if I have to ask this. ive been converting my lights to projector housings and want to use hids in the fogs but dont want the warm up time of hid's when switching back and forth between low and high beam yes the fogs are not yet projectors but i have the parts to do it and just have to actually do the mod. wanted to get the wiring done first. the low beams though are freekin sweet and thankfully because the lows stay on with highs on these cars i was able to use the projectors for both low and high. Edited March 7, 20206 yr by sirtokesalot
March 9, 20206 yr I just did it on my '00 Outback, and did a how-tohttps://www.subaruoutback.org/threads/fog-light-modification-how-to.519679/
March 9, 20206 yr On 3/5/2020 at 7:35 PM, heartless said: not sure why you would want to do this, since the fogs would basically kill the distance vision of the high beams (which is why they are the way they are from factory) fogs are meant for use in poor visibility conditions, not general driving use. but to each their own i guess On my 03 outback the stupid low beams stayed on when the stupid high beams were on. drove me nuts.
March 9, 20206 yr 24 minutes ago, CNY_Dave said: On my 03 outback the stupid low beams stayed on when the stupid high beams were on. drove me nuts. Drove you nuts? That's what they're supposed to do.
