May 23, 20205 yr Dowel pins to mate EA82 engine to tranny are stuck in the old motor and I destroyed them trying to get them out; they need to be on the tranny side for my adapter plate. Does anyone know if these are still available from Subaru? Haven't had any luck so far looking through online parts diagrams for a part #. Thanks
May 23, 20205 yr I know when I was after an internal dowel for the gearbox the answer was dowel comes as part of the casing i pulled a perfectly good box apart to get another little sucker .... Edited May 23, 20205 yr by Step-a-toe
May 23, 20205 yr Don't know, but they are pretty likely standard metric dowel pins. Decent car parts store might have them, just as generic parts. I usually check Mcmaster-carr for things like this also.
May 24, 20205 yr Author They were seized in there pretty fierce. I got one out after battling with some vice grips. I'll take it in to NAPA and try to get something "close." Thanks guys.
May 25, 20205 yr I’d clean it up and reuse it. Not a critical part. It’s job is to align the engine and gearbox with more precision than the mounting bolts. Being slightly smaller won’t matter. Cheers Bennie
