EA81 oil pump autopsy
The worst one I have seen to date
I can see wear from the cam drive
The other end of its drive shaft has been scratched up wearing into the housing and the other rotating parts much the same
The O rings, evolved into flat and square cross sections as expected.
I wonder if I should still save it for someone in desperate need to keep a junker running. The housings are not broken at least.
Apply within
If desperate, I reckon a machinist would trim a little off the pump end, fit a sintered bronze bushing in pump body ..
5 hours ago, GeneralDisorder said:
Send it to the smelter.
If someone really wanted to, they could install an external pump.
Like a dry sump rally set up?
