swap T71 Transmission to T81W
I have two Subaru's 1981 hatchback one has a bad T71 Transmission FWD and the other has a T81W 4WD transmission in good shape, I need to swap and I need some advice, I will appreciate, the car titles says both are 1.8 but the FWD has a EA71 engine the other has a EA81  engine, I am fixing to use the FWD  into 4WD.
What can I do?
Thanks
Thanks for your reply I will check And let you know.
15 hours ago, GeneralDisorder said:
Depends on if the bell-housings match. Are they both side-starter or is the EA71 a top-starter?
there's EA71's that don't have the starter on the top?
Generally found from late 79 production-wise thru the end of the 1600 , I’m guessing 1987 the latest here in the States.
80-84 sedans wagons hardtops coupe
later for the hatchback which was labeled an STD , or fleet car for the latter years. I have thought they were long finished (1600) and yet I had come across one of those later hatchbacks in a boneyard and was surprised for sure. They came with rubber mats instead of carpet , and generally not much in features and a very “wipe able” interior. And they became “managed” unlike the early gen.
