November 15, 20205 yr Looking for a friend who has a 2007 Subaru that need rear wheel bearings, I came across the replaceable unit, 2010+ Is it possible to get a newer unit and retro fit it to an earlier Subaru? If you went to the yard and pulled a 2010+ rear hub, could it be bolted in to an earlier Subaru? Thanks, Larry
November 15, 20205 yr Depends. 2005+ Legacy rear bearings are bolt-in. Impreza did not get any bolt-in bearings front or rear till 2008. I couldn't tell you what will interchange without model information and in any case it's easy to lookup the parts on parts.subaru.com and check the interchange. GD Edited November 15, 20205 yr by GeneralDisorder
November 16, 20205 yr On 11/14/2020 at 6:45 PM, lmdew said: a 2007 Subaru... Subaru, what. Rear bearings went to bolt in hub assemblies when the rear suspension went to multi-link, so the knuckles are completely different. So, ASSuming this 2007 Subaru is Impreza based, you get press in bearings.
November 17, 20205 yr Author Thanks. I was looking for a friend with a 2007 Forester. Should have put that in up front.
