January 2, 20215 yr I’m looking for a manual transmission for my 1990 Legacy AWD station wagon. does anyone know of other years/models that would also fit so I can broaden my search. Also will a trans from a 90 Legacy sedan also fit the wagon. Thamks
January 3, 20215 yr As long as you use a matching rear diff for whatever you get, you can use basically any AWD Subaru 5 speed up till they switched to hydraulic clutches - after that things get questionable as to having the clutch fork ball mounting boss..... For sure up through about 96 on the Legacy, and through 2001 on the Impreza. GD
