Transmission Alternatives/1990 Legacy
As long as you use a matching rear diff for whatever you get, you can use basically any AWD Subaru 5 speed up till they switched to hydraulic clutches - after that things get questionable as to having the clutch fork ball mounting boss..... For sure up through about 96 on the Legacy, and through 2001 on the Impreza.
