September 7, 20214 yr Good afternoon everyone, first of all I'll just hi. This is my first post here and I look forward to being able to help people and also soak of some of this knowledge for myself. Now to the business end of things haha. I have a 1997 Subaru Impreza Outback Sport 2.2L / Automatic Transmission. The speedometer recently stopped working and it gave me some codes P0500 and P1540 (which is specific to speed sensor 2 - passenger side of the from differential just in front of the dip stick). Also out the car into limp mode and the things that come with that. I did research online, I also have the workshop manuals and 9/10 times the speedometer cable meter seizes and the end snaps off (or it shears off for some other reason). You'll see in the photo it was running dry and quite gouged. Sure enough I pull it out and the end is snapped off and still in its place, turns out it's not magnetic so fun times getting that out. I got the small piece out and inspected the actual meter itself and tried to turn with a screw driver and no go. I turned the speedometer cable and it turned just fine. So my conclusion is the high pitched sound I heard coming from the front end that I wasn't able to diagnose for the last month was this pice haha... Ill attach some photos that match my commentary. With all the being said, where can a guy find this part ?Part# 737411752 / part code 37410B which is the mechanical version. The bottom side slots down into the differential and the top is where the speedometer cable clips into. I called Subaru and was told it's been discontinued for awhile and no parts available in North America, I also emailed a few Japanese sites and same thing no stock. I think I'll just have to wait for pick n pull to get a compatible vehicle in for me to pull one out of, but I thought I would ask around here as well. Thanks for your time, I appreciate it. Edited September 7, 20214 yr by 700 Adding photos
September 8, 20214 yr Author Ok bear with me as I have never used the website before or even anything similar for the matter. So how it works is you enter the vehicle information in and the part you're looking for, you fill out the form and then the website forwards it to auto recyclers and places like that. So they actually check if they have the part, pull it for you and ship it to you ?
September 8, 20214 yr Order a new adapter from Subaru. Very common failure. https://www.amazon.com/Subaru-Automatic-Transmission-Speedometer-737411752/dp/B01MG60SP2 I wouldn't trust a used one. Most of them look pretty beat to he11. GD Edited September 8, 20214 yr by GeneralDisorder
September 9, 20214 yr Author 7 hours ago, GeneralDisorder said: Order a new adapter from Subaru. Very common failure. https://www.amazon.com/Subaru-Automatic-Transmission-Speedometer-737411752/dp/B01MG60SP2 I wouldn't trust a used one. Most of them look pretty beat to he11. GD Yes this is exactly the one I need however as I mentioned in the first post Subaru is out of stock and the Amazon link it says currently unavailable. Ideally I will find a new one somewhere. Edited September 9, 20214 yr by 700
September 9, 20214 yr Go to the US Amazon not the derp Canadian one. Here in 'Merica the link shows 7 available. GD
September 9, 20214 yr 18 hours ago, 700 said: Ok bear with me as I have never used the website before or even anything similar for the matter. So how it works is you enter the vehicle information in and the part you're looking for, you fill out the form and then the website forwards it to auto recyclers and places like that. So they actually check if they have the part, pull it for you and ship it to you ? you can do it that way, and any that have the part will send you a price quote. most wont actually pull a part (if it isnt already on a shelf) until they have an actual order for it. or you do a search for the part, and peruse those that claim to have it... many will list prices, others say to contact them for price. you can search by region & distance from a specific zip/mailing code
September 9, 20214 yr Then find that the ones who have it either won't ship north of the border, or will do so for two or three times the cost of the part. This is why I have a Montana mailbox.
September 9, 20214 yr 5 hours ago, jonathan909 said: Then find that the ones who have it either won't ship north of the border, or will do so for two or three times the cost of the part. This is why I have a Montana mailbox. Yeah but 2x the price of the part is still less than $50. And in this case "used" is no kind of option in my experience. GD
September 9, 20214 yr Author I guess today was my lucky day, I pulled up the pick n pull website did the usual search. A 1990 Legacy Wagon came in with matching specs to my car, so I go there and sure enough the part I need. I pulled it out and took it home and installed (after cleaning and lubing). I have a working speedometer again. There is a lot to be said about how advanced Subaru was back in the day, the legacy I pulled the part out of was the top of the line trim I imagine, even with electronically adjustable height. Thanks for the help everyone, I will be able to use the resources in the future I am sure.
