July 22, 200421 yr I've noticed over the past few weeks that my car isn't as zippy as it once was... Redlining it on my way to work this morning, I noticed that the boost pressure was about 2 psi less than normal, and the needle was fluttering, like shaking back and forth about half a psi. This is probably a boost leak somewhere, right?
July 22, 200421 yr or exhaust leak before the turbo. make sure the mounting bolts are tight. they like to back off with heat.
July 22, 200421 yr I don't have any experience with older Subie turbos but on my WRXs an uppipe leak is easily recognized by the high pitched sqeal it makes while under boost.
July 22, 200421 yr Author or your wastegates poopin out. you can usually hear a bad boost leak. What precisely does that mean by pooping out? If the wastegate was stuck open, it wouldn't make any boost at all, right?
July 22, 200421 yr Hi, I have an ea81T with a high pitch sqeal under boost. Probably a stupid question but which pipe is the uppipe?
July 23, 200421 yr Hi, I have an ea81T with a high pitch sqeal under boost. Probably a stupid question but which pipe is the uppipe? the pipe which feeds the turbo....
July 23, 200421 yr its a boost leak. manny, pull the intercooler off and check the hose that connects the turbo to the bottom pipe of the intercooler. might be a good time to replace the hoses for the bypass valve and mass air flow meter pipe as well...all of this might cost you $20 at home depot.
July 23, 200421 yr Author its a boost leak. manny, pull the intercooler off and check the hose that connects the turbo to the bottom pipe of the intercooler. might be a good time to replace the hoses for the bypass valve and mass air flow meter pipe as well...all of this might cost you $20 at home depot. Hey Dennis, Good to see ya around. How ya doing?
July 23, 200421 yr My boost leak story goes as follows, First run with the intercooler I would get a very noticable swishhhhhing noise on boost, didn't have a boost meter to see what the psi was. yesterday I had a intake manifold vaccum come off, absolutly no extra noise but my max boost dropped from 6~7 to 3~4 psi, so I would say check your vaccum lines. Good luck
