88 gl waggon spfi no spark or fuel
About a month ago i was filling the coolant and pulled the cap after a few heat cycles and it shot coolant all over the battery and main connectors and distributor, it ran rough but would start then after a little bit it wouldnt start...i could hear the fuel pump kick on and off priming the system and very rarely it would start then i decided to clean every connection  and grounds, but after all that i have no fuel pump surge or spark or fuel and i have no idea where to start other then the fuzes and grounds and all fuzes and grounds are good....any help would be greatly apreciated
Yes i replace them as well ecm is not throwing any codes iether and i just check all the relays and they seem fine
Coolant tanks don't shoot out coolant unless you have cracked heads, in my experience with a turbo.
  • 1 month later...
The system was empty when I got the car and was burping a huge air bubble it doesn't lose coolant, but I ended finding the issue and it was the ecm had a buddy come down with his and it lit right off thanks for all the suggestions
Update found 2 burn resistors  and soldered them in and it fires right up
Yes.  both were rated for .57 ohms and had OL and the other 450k ohms  and I notice after replacing them both my oil pressure gauge reads accurately now
Edited by Issac
Do you think they blew because of the coolant spill, or just a coincidence they blew after you happened to spill coolant?
I'm not sure to be honest it's posible but with it an intermittent issue at first I think I had a bad connection and the bad connection caused it
It was r1, and r63 on the board it won't pet me attach an image
