cherrythesubaru Posted June 20 Share Posted June 20 Hey yall! Just joined the Subaru crew with my '92 Loyale, Cherry. She sat for a year or so with a broken timing belt before I got hold of her and had a lot of somewhat "frankenstein" style work done by the previous owner. Here's where I'm at: Did timing belts, oil change, oil filter, spark plugs, checked all fluid levels, and replaced old fuel. I had some trouble getting her started until replacing the fuel filter (old Fram filter leaked cloudy brown fuel when I cut it out). After replacing the fuel filter it still usually takes a few tries before I can get her started and the idle is quite rough and can sputter out with too much throttle while cold. Some warmup time will typically help the idle settle in and allow me to rev to about 3500rpm although I get lot's of backfire and sometimes the engine stalls coming back down. When I try to put it in gear and ease off the clutch the engine feels like it's going to die immediately and will typically stall out with extremely minor load (backing out of an angled driveway, for example). I was able to feather it out onto the street and get into second gear but it can barely get above 15km/h without some major finesse and painful noises. My first instinct here is a fuel issue but I know it could be a lot of other things and would love any help yall can provide. Cheers! Link to comment Share on other sites More sharing options...
moosens Posted June 21 Share Posted June 21 Have you checked your timing to make sure it didn’t skip a tooth ? Not sure how you did but I like to use clamps on the cams to hold the belts in place, get that last loop of the belt over the toothed gear which I leave loose until the belt slips over, then you can easily release the tensioner and your belt shouldn’t move. Just a tip. I’m guessing you have plenty of experience with other makes. Distributor ok ? No play side to side? If it is fuel your pump sits on a little shelf in back under the car on the right side. Getting hard to find replacements but maybe not so bad for this generation. I think Walbro made a good one for the EA82 FI cars. Post back what you found, and good luck. Some folks may also suggest the pressure regulator. Link to comment Share on other sites More sharing options...
el_freddo Posted June 21 Share Posted June 21 Did you fit one cam belt, rotate the crank one rotation then fit the second belt? If not, this is your issue. I learned this the hard way. Your engine is probably running on one bank/side while the other does nothing. It will start with difficulty, and be completely gutless to drive. Cheers Bennie Link to comment Share on other sites More sharing options...
cherrythesubaru Posted June 21 Author Share Posted June 21 Thanks for the replies! I followed the procedure in this video for timing and double checked the holes are opposing on the two cams and align with the seams but can’t hurt to triple check. I also made sure to rotate the crank one full rotation after fitting the first belt. Checked the distributor alignment and that I have spark on all cylinders. Hoping it’s just my spoob mechanical skills and not something expensive 🤞 Will let y’all know what I find. 1 Link to comment Share on other sites More sharing options...
subaru1988 Posted June 21 Share Posted June 21 (edited) That video is OK, but kind of short on detail. Do a YouTube search for "Miles Fox EA82" and watch his timing belt video. He posted on this board for a long time, and his videos are good ones that have a lot of why you're doing what you're doing instead of just how to do it. Edited June 21 by subaru1988 2 Link to comment Share on other sites More sharing options...
cherrythesubaru Posted June 21 Author Share Posted June 21 Thanks! Love Miles’ videos! I watched the Miles fox video first but it didn’t include the distributor section so just shared the Nice Guys one here for reference. Any chance I can get Miles to come take a look at my car? Haha Link to comment Share on other sites More sharing options...
cherrythesubaru Posted June 22 Author Share Posted June 22 (edited) Checked the timing and it looks good to me. Both cams are in line with seams and pointing in opposite directions. Today I’m getting really tough start and about 5 seconds of idle before slowly dying. Giving it gas while trying to start kills it right away. Edited June 22 by cherrythesubaru Link to comment Share on other sites More sharing options...
scoobydube Posted June 24 Share Posted June 24 Your descriptions sounds like a problem I had when the Exhaust Gas Temperature sensor in the exhaust needed replacing. $25 You also might want to change out all of the relay switches under the dash over your left knee cap. Make sure all the breather hoses are soft and get a good seal, as the rock hard breather hoses on top of the engine no longer seal. See my thread on Rock Hard Breather Hoses. Make sure that the timing advance vacuum on the distributor still holds a vacuum when you suck on the inlet. Take apart the distributor if it is not an electronic distributor, and make sure all of the swing weights are not worn on their pivot, have grease on them and they swing properly. Make sure the distributor cap is not cracked. Verify that the engine problems do not occur only when you are running accessories. If accessories cause the engine problems then you need to change out your engine ground at it's left front connection to the frame, and also look for rock hard electrical wires running from your + positive battery terminal to the bottom side of the fusible link box as it loses it's ability to carry current. 1 Link to comment Share on other sites More sharing options...
cherrythesubaru Posted June 25 Author Share Posted June 25 Thanks Scooby! I'll give those a try if the fuel issue diagnosis doesn't solve it. Update: I tested the pump and it seems to have good flow. After a bit more diagnosis, I noticed that when starting cold giving it some gas almost instantly kills the engine. To me that seems like it's running rich and would point to a fuel pressure regulator. I bought a new regulator off Rockauto but it didn't fit despite their website saying it was compatible. Got the Delphi part #FP10485: https://www.rockauto.com/en/moreinfo.php?pk=10910396&cc=1270134&pt=6124&jsn=1162 The only other option on Rockauto is Intermotor part #PR263: https://www.rockauto.com/en/moreinfo.php?pk=817733&cc=1270134&pt=6124&jsn=1161 Has anyone else had issues finding a regulator and, if so, where did you find a viable replacement? Cheers! Link to comment Share on other sites More sharing options...
moosens Posted June 26 Share Posted June 26 Last line in my post above. Lol I might have one still. I don’t have EA82 items in general but I can picture one in a plastic multi drawer thingamajig. Don’t hold your breath though. Otherwise I would hope one of us has one or find a yard with one sitting around. Good luck and please post back with your results. 1 Link to comment Share on other sites More sharing options...
scoobydube Posted July 5 Share Posted July 5 An EGR red light on your dash would indicate that either your EGR valve has issues or your EGR solenoid has issues. A faulty EGR setup can cause the problems that you describe, according to the Subaru manual and CoPilot. Link to comment Share on other sites More sharing options...
scoobydube Posted July 5 Share Posted July 5 Although I recently had similar symptoms, I finally read the trouble code and got 14. Copilot told me that my #1 cylinder injector was malfunctioning. Upon inspection, there was lots of white corrosion inside of the connector. Scratching as much of that corrosion off, not only made the engine run normal again, but it meant that I did not have to go shopping for another car. Win-Win. Link to comment Share on other sites More sharing options...
cherrythesubaru Posted July 15 Author Share Posted July 15 Update: Found a regulator that fit but the symptoms persist. Thanks for the insight here, Scooby! The owners before me seem to have made a lot of changes to the electrical so I'm not certain I'd be able to pull reliable codes. That being said, I'll see if anything you mentioned above RE: EG temp sensors, breather hoses, EGR valve etc. are causing the issues. More diagnostics to come! Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted July 16 Share Posted July 16 I had an issue somewhat similar to what you're experiencing. My GL would start, only with throttle input and would idle like garbage. But it would smoothen out at slightly higher than idle rpm. What it ended up being is a broken IAC wire in the engine wiring harness. I had to test for continuity while bending the engine harness to try to find the break in the wire. Took me longer than I'd like to admit to find since the IAC tested okay. :] Link to comment Share on other sites More sharing options...
cherrythesubaru Posted Friday at 08:35 PM Author Share Posted Friday at 08:35 PM @scoobydube Had some time to check the engine for an EGT sensor issue and looks like my model does not have one. Went ahead and checked the coolant temp sensor and it did have some white crud on it. After cleaning the sensor, the engine started up right away and then idled at 2000rpm before starting to climb without touching the throttle. I gave it some gas to see if it would come down to normal idle levels but the engine puttered out. Now I'm back to no start. Might try swapping the coolant temp sensor first to see if that's been the issue all along. Link to comment Share on other sites More sharing options...
moosens Posted Friday at 10:36 PM Share Posted Friday at 10:36 PM Luckily those cars are still fairly simple. Good luck with the chase. Old school guy like myself would ask how the exhaust smells when that’s occurring? But sure just swap in a good CTS and check the other notorious items from the EA82 era. Link to comment Share on other sites More sharing options...
SuspiciousPizza Posted yesterday at 12:49 AM Share Posted yesterday at 12:49 AM Have you checked if the throttle position sensor is set properly? Just a thought I had while reading this discussion. My opinion is to check everything you can before chasing the parts dragon. Though it is always good to have spare parts while they're still sparsely available. Never a bad idea to buy a spare if you have the scratch IMO. Link to comment Share on other sites More sharing options...
