el_freddo Posted 5 hours ago Share Posted 5 hours ago 8 hours ago, bushytails said: You're doing it wrong... you take off the shocks, then the three bolts on the trailing links, then the inner bushes, then drop the gas tank, then bolt up the 4x4 gas tank, the mustache bar and diff, and the trailing links with CVs... don’t forget to swap in the “K frame” that all mounts from, it’s got the front upper mount for the rear diff Cheers Bennie 1 Link to comment Share on other sites More sharing options...
bushytails Posted 3 hours ago Share Posted 3 hours ago Hrmm, I could have sworn the 2wd still had it, but it's been so long since I've seen one, I seem to be mis-remembering! Link to comment Share on other sites More sharing options...
Durania Posted 2 hours ago Author Share Posted 2 hours ago 9 minutes ago, bushytails said: Hrmm, I could have sworn the 2wd still had it, but it's been so long since I've seen one, I seem to be mis-remembering! You're not the only one. I fortunately, didn't spend much time directly under the brats that I owned. If anyone has any spare parts, shoot me a PM. Link to comment Share on other sites More sharing options...
