Air Struts: Repair, Replace, or Swap?
Howdy!
I'm continuing to work on my 1986 XT Turbo, I had just finished rebuilding the breaks and was about to take her on her maiden voyage and as the compressor is going, I hear a quiet "psssh" which turns to a quick and louder "PSSSH". I am able to hear and feel a hole in the rubber boot on the driver side rear shock. It feels like it's right in the middle of the boot, about an 3/4 in wide. What's the best method for repairing these? Just a tire patch of some kind? or maybe some kind of thick rubber band? Or is it better to see if I can find a replacement on Ebay. Or should I give up on this 80s dream and go the practical route of replacing with regular coil and struts 😆.
Thanks in advance,
Philly
One vote for Replace with Struts.
Did it with a wagon. Was so worth it.
Had an XT with same situation but never fixed it. My poor sister in law suffered that XT hardtail for a while before she’d had enough. Only reason to refresh or replace with same would be listening to your heart. My opinion.
Hmmm, I think I'm going to at TRY to repair them, but as a backup, I'll get myself some regular struts. Do you know if the struts from an 89 XT6 would fit in an 86 without much issue? Or should I go for something else?
I’m not sure but i would think the XT6 is a little different ratio and might hold the nose up somewhat, or a general body lift by about 1/2” or so.
Only a guess.
Such little activity here compared to years back pre- FB but if you haven’t already so check the archives.
I doubt you’ll find replacements other than the odd second hand unit that rarely comes up for sale.
It would be cool to keep the air struts, to do that you’d probably need to find a suspension shop that specialises in this sort of thing. Take the struts in and leave your platinum credit card with them too. I’ve heard the air suspension rides very well.
Any 4wd L series struts will bolt straight in. That will be the easiest way to get your tex on the road while you decide on/sort out/bin the air struts.
I forgot to take a picture of the damage, but the hole was WAY bigger than 3/4 of an inch. It was on the reverse side so I couldn't see it at first. Maybe an inch and a half, right in the middle where it bends. I'm trying to rubber cement and a large rubber batch on the outside and then letting it cure over night. If that doesn't work I'll try to take the whole thing apart and do a patch on the inside and outside.
If all else fails I've taken the regular struts off my, destined for the junk yard, XT6. You're right el_freddo, looks like it'll bolt right in.
Sad to see my old XT go but her sacrifices will not be forgotten 😔.
I wouldn't expect any reasonable repair to hold...  And if it did, it'd just pop somewhere else next week.  It's not like a tire where an object punctured it - it exploded because the material has failed with age.
Well, unfortunately my brilliant plan did not work. Not super surprised but still disappointed. I agree with you bushytails, that rubber is just too far gone, and even if I did fix it, who knows when the next one would go. I think my new plan is going to be to take them off, take them apart, and replace the rubber entirely with a similar material, or something that can hold the pressure. I am not sure how any of it is built, so if anyone has any details on what kind of rubber it is, or how the thing is put together, that would be super helpful. There seem to be some detailed plans in a 1988 manual that I found online, hopefully that should suffice.
I haven't found any detailed information on how to rebuild those struts online, so I will do my best to wing it and document what I do here. Maybe do a little guide so that future people can do the same.
Until then, I'll there is a junk yard north of me with an 86 GL in their lot. I'll take the conventional suspension off of that, replace the struts and use that until I finish the rebuilt of the air suspension. Wish me luck!
Good luck but i think you should be happy with springs or shop a true contemporary set up from the bag culture.
I don’t see those as easily serviceable units. Let us know how it all shakes out.
Small update, I was able to find some conventional struts at a yard in my area and they went on just fine! At least, the rear ones did, I haven't done the front ones because I wanted to try out a little experiment. What I have learned, is that you can have the front air suspension independently from the rear, as long as your plug up the rear. I used the solenoids from the rear air struts and plugged them into the airline and just left the power unplugged, which leaves them in a closed state. Not exactly a revelation, but still fun to know. This wont be long term of course, but I did drive it around my neighborhood, and it didn't explode so that's a win in my book.
It does lead to a somewhat silly look on the car when the front struts are deflated. The attached picture doesn't do it justice, but hopefully my MS-Paint art shows what I mean. It basically has a very aggressive attack angle which really made me laugh when I first saw it. image.jpeg.a04ad25a1c80a1d7eb9af1d152b25a64.jpeg
Well, in my infinite genius I made a pretty big oopsie. While replacing the front struts, I somehow broke the driver side drive axel! I can fill it in the boot, its somehow become detached at the joint where it meets the hub. I must have bent it in a bad angle or something. I was able to get a replacement, but my predicament is this: In a video by a Miles Fox on YouTube, he pops out the axel out of the transmission using a breaker bar against the hub, however since its broken at the hub, what would be the best way to get it out? I have replaced an axel before in a Jeep, and it was able to just come out, but from what I can read in the manual and see in the video, these seem to be different, with a slide pin and stuff.
Were you pulling on the knuckle or some component away from the car? Like you're facing the car as if you're removing a tire and pulling the knuckle towards yourself.
I'd remove the boot clamp to inspect what happened. On the outer joints, there's a little metal circlip that fits into a groove on the axle shaft. This clip prevents the axle shaft from pulling out of the inner joint. My guess is that's what you did. Pulled the axle out of the inner joint.
All you should have to do (if that is the case) is take the clip, put it in the groove and shove the axle back into the inner joint. If you need a spare clip, I have some.
I seriously doubt you actually broke the axle with arm strength alone. If you did, you should drop the wrenches and pick up a speedo for a bodybuilder competition ;)
In the future, best way I've found to remove the axles from the transmission is: remove the roll pin on the inner joint (6mm needle punch), remove the two engine mount nuts, remove the front engine pitch rod bolt, remove the transmission mount nuts, use a jack with a block of wood to lift the engine and transmission up 1-2 inches DON'T LIFT FROM THE OIL PAN LIFT FROM THE TRANSMISSION (watch your fan so it doesn't hit your radiator or fan shroud and make sure you're not pulling any hoses, wires, or cables) then you can pull off the axles. You just need to give the transmission a little lift to get enough clearance.
Edited by SuspiciousPizza
Forgot to mention removing the engine pitch stop bolt
Thanks for the wisdom! What I did exactly was, unbolt the stabilizer from the from the transverse link, and loosen the bolt holing in the link so I could bring it down, I then took out the old air struts and then put the new one in. I couldn't bring the knuckle down low enough that I could slip the strut into the hole of the knuckle from the bottom, but I could bend the knuckle at an angle and then pop the strut into the knuckle (This is after I had loosened the bolt at the knuckle, and sprayed some WD40 to help it slide in). I had done this with the passenger side and it's not having issues, but I am now going to inspect that to make sure it's not about to fall apart. On the passenger side it was loose enough I could use my hands, however on the drivers side, I used my leg since I was close enough to the wall. Below is some MS-Paint art to illustrate my "infinite genius":
I think I see what you're saying about disconnecting the joint. Tomorrow I'll take off the boot and see what's going on in there. I am assuming I'll need an extra pin, but we'll see, I'll reach out if I do and I'll gladly pay for it.
Thanks, el_freddo, it truly is the highest quality of art.
I was able to move the boot back and take a look at the inside, and it looks like the shaft thing has come apart from the spindle thing. According to the (1988) manual, there is a snap ring that holds it in, somehow? I will have to take the whole thing out and on the table to really see what's going on. I just got a 1986 service manual, so I'll be sure to take a look at that as well and confirm that snap ring was present in the 86 models as well, although I'm sure I'll find out once I take the thing apart. Hopefully when this is all done, I'll actually get back to working on those air struts lol.
I love the technical terms used in the illustration. Haha.
A few things when disassembling/assembling axles:
Inner joints (transmission side): These have a large diameter metal clip close to the outer edge of the bearing cup. Just use a small flathead screwdriver to get this started and remove it. Take photos of the orientation of the outer bearing retainer, it is unidirectional. Remove the bearing carrier/retainer as an assembly, use your small screwdriver to pry the bearings out (be careful to not scratch the surfaces, use a cheap screwdriver they'll be softer than nice ones), then turn the outer retainer and it'll separate from the inner carrier.
Outer joint: These joints have the metal clip I was mentioning above. If this joint wasn't accidentally disassembled when you were putting in the strut then leave it be. They're not supposed to be disassembled but they *technically* can be.
Only use molybdenum disulfide grease when assembling the axle. Make sure the axle is clean of grease before regressing and reassembling. Zip ties can work as boot clamps, but I'd recommend actual boot clamps.
Metal zip ties are awesome to use too. Just ensure you get plenty of pressure on the boot before cutting the tag end short. Roll the remaining tag end over the zip tie’s clamping piece. This locks it in somewhat.
