Rich Mixture, Misfire, Stalling
EA82, SPFI, 5MT D/R.
My engine runs *okay* and can do short back an fourths to work alright.
However, it has a misfire. The entire throttle body (injector, TPS, and regulator included) is a "good used" part. My fuel pump is also noisy and I have no idea when it was last replaced.
TPS is properly setup. Used the 2 feeler gauges.
Once I've been driving for a while, sometimes it'll run like a top. Buttery smooth. Other times it idles rough. It doesn't buck the car side to side but it does vibrate. A noticable gas smell comes from the driver side and the plug for cylinder #4 has more carbon buildup.
I've had the engine stall 3 times after coasting to the bottom of a hill and pushing in the clutch. My guess is the rich mixture floods as I'm coasting and not burning all of it off. Then once I clutch in and the RPM's drop, the mixture is too rich and it just stalls.
I've swapped in hotter plugs with a tighter gap, cleaned the MAF, and checked my timing (15deg BTDC. I'm using carbed cams on a SPFI setup). Coil, alternator, plug wires, battery cables, PCV, and CTS are all new. I don't have any codes. All engine hoses are new.
My guess is it's the fuel pump, injector, regulator, or the distributor. (Cap and rotor only have about 3k miles on them).
Could also be a tuning issue. I have not fiddled with the idle control.
Any thoughts or ideas?
I noticed something today while I was leaving work.
It's starting to get cold here so I let the car warm up without the heater running. As I was going to leave the first thing I did was turn the heat on. Hmmm. The idle dropped 300 rpm and started to sound like it wanted to stall.
Perhaps I have some sort of vacuum leak and that's causing the issues. The EGR valve operates with vacuum. Maybe it's not operating properly due to vacuum loss.
Perhaps this is causing my fuel smell?
Some time in the next few weeks I'll run a D-check, do a fuel pressure test, and check for vacuum leaks.
I've given the entire engine bay the smell check for fuel leaks and didn't find anything. I don't smell gas in the garage either after it's been sitting overnight. I do keep an extinguisher in the car though.
Try the spray test on those hoses? While it’s running spray some WD-40 around the vacuum hose ends all over until you notice a change in idle.
No funky smoke from the tailpipe ? A little white? A little black ? Normal ?
No funky smoke. Exhaust definitely smells of fuel though.
After I've been driving, the hot idle is at about 1k vs when I cold start, it'll sit around 750.
Could a vacuum leak caused by the HVAC system cause the EGR valve to not open appropriately?
I bought the cheapest vacuum gauge from a decent brand I could find so I'll be hooking it up oil crisis style. Diagnostic tool + fuel savings.
I should also note I'm not 100% convinced I'm experiencing a misfire. It very well could be excess fuel in the exhaust burning off causing the illusion of a misfire when I put my hand at the tailpipe. I lack the experience required to say for sure, I'm definitely still learning.
Edited by SuspiciousPizza
I've been driving around with the vacuum gauge installed for a few days and here's what I've found (other than the constant roller coaster hills in my area destroy my fuel economy).
On a cold start the vacuum seems quite low (13-15 inHG) and it flutters (correlating with a rough idle on cold start) within a range of 1-1.5 inHG. After the engine is at full operating temp, at idle it'll sit quite steadily at 20 inHG. However, my idle has a rhythmic roughness where the vacuum will drop about 1 inHG and it'll flutter slightly more when it drops. The rhythm is about 2 seconds smooth idle then 1 second rough idle, smooth, rough, smooth, rough, etc.
My vacuum seems on the low side so I'll get some fuel pressure gauges spliced in and see if advancing my timing to the factory spec of 20 BTDC smooths anything out.
Any ideas or thoughts are appreciated.
Sounds to me like a timing or air issue. I would bring the timing to 8-10 degrees BTDC because of the carb cams and see what happens. You said you cleaned your MAF, so that shouldn't be a problem, but your O2 sensor could be sending slow signals.
I do not have an O2 sensor nor an EGR temp sensor.
My coolant temp sensor is a good quality sensor and it's basically brand new. New doesn't mean good, I haven't tested it but I'd be rather surprised if that was the culprit.
The car has always had a fluttering idle, even with a completely different engine.
Also it's a D/R so there's no 4WD vacuum assembly like on a SR4WD. I wouldn't be surprised if the HVAC system has a leak. I'll give the hoses behind the dash a look.
Interestingly the vacuum flutter on cold start isn't as bad and subsides much more quickly if the oil was preheated. Maybe one cylinder has bad rings?
I brought the timing up to 15deg and I was pinging on regular. No issues with pinging when running premium. The heads have been resurfaced for sure once. No clue on their prior history.
I'm not sure how the ECU learns mixture and timing curve but perhaps the ECU is expecting SPFI cams and the carb cams are making it freak out? I doubt this but it's a thought I had.
I doubt there will be too much of a difference between carb cams and EFI cams. Turbo to NA cams, yes, quite a difference but even then the ECU wouldn’t care too much if at all.
Cleaning the MAF can induce loads of issues if not done properly. Even then, many seem to report that the MAF is never quite the same after a clean if not done gently enough.
Not having an O2 sensor would be an issue for the ECU. Why is this missing from the system?
As for
timing and pinging, my brumby sits on 4°btdc and runs the best RON “pump gas” we can get (98RON). Any more timing and it pings its tits off. Summer driving can be an issue with pinging at times.
If your HVAC system is leaking vacuum that can be fun to diagnose - unless it’s a hose off which will hiss when selected (if post dash switch) quite loudly, enough to know you have a leak. The actuator diaphragms might mask the noise a bit better, however, in my Lseries with 530,000km on it they’ve never been an issue and not replaced in my ownership of 20+ years.
I hope you get this sorted. Nothing more annoying than these little issues with no obvious solution.
I believe not all SPFI cars here in the US came with an O2 sensor. California has more strict emissions regulations than the rest of the nation. The California cars got O2 sensors, the cars sold in all other states do not have O2 sensors. I believe. Regardless, not all SPFI cars have O2 sensors from factory.
I have found it interesting that despite my car originally being sold in California, it doesn't have California-spec emissions equipment. It has the national standard emissions equipment.
I believe the national standard is just an EGR setup and a charcoal canister. No O2 sensor and no EGR temp sensor.
  • Thanks 1
  • 2 weeks later...
I don't want to speak too soon but I believe I've fixed the issue.
As I was going over the vacuum hoses and trying to hone in my timing I got a check engine light. Code 34 EGR solenoid. Bugger!
On my other engine I was using a Toyota EGR solenoid. I used a "good" OEM solenoid on this setup. Well turns out that solenoid wasn't good.
I swapped my trusty Toyota valve back in and it runs like a top. Vacuum at idle is strong and steady between 20-21 inHG. No more fuel smell.
I'll do some city driving tomorrow to test it out. It likes to act up most with frequent starts and stops or rapid deceleration to a stop.
Yep I spoke too soon.
Went to start my car this morning before work and I got a CEL. Double bugger.
Code 35, purge solenoid.
So I'll be doing some tests tonight after work to see what's going on.
If I need to, I'll be replacing the solenoid with the same model I used for my EGR solenoid replacement. AISIN VST-026. Boy have the price of those jumped since I last bought one! Nearly double the price.
I went to inspect the purge solenoid.
24.5ohms resistance. Hmm the valve is good. Maybe there's an intermittent connection.
Tested the engine harness. Continuity checks okay.
Tested the harness between the ECU and the engine. Continuity checks okay.
Maybe it's the ECU. I swapped in a different ECU. No more CEL and now the RPM's drop gradually versus with the other ECU they'd drop rapidly when the engine got to temp.
Maybe it was an ECU issue? I'll see how this one does.
Fouling after driving down the hill with clutch engaged, would likely be the pistons sucking oil past the rings into the combustion chamber.  The dirty plug would confirm that.  There is an mixture adjustment screw on the top of my intake manifold.  You lean it out by unscrewing it and getting the highest idle rpm.  You stop unscrewing it just as the maximum rpm is reached.
I would not be surprised if my rings were bad. That'd explain why my vacuum flutters on start up then quickly subsides within a minute.
The throttle body I'm using is a junk yard unit so no clue if the previous owners tried to adjust the mixture.
There is still a fuel smell to the exhaust. It's so weird because it went away after fixing the code 34, then it came back.
At least now it's running without throwing a CEL or codes.
That's a great question. I'll have to do a compression test when I go to my buddy's to use his shop. Our work schedules and other plans makes it difficult to find the time to meet up.
It seems to be running better with the new ECU. Not perfect but I trust it for driving to work and back. Which is all I need the car for.
I noticed it'll stumble after I start it when it's hot. Say I get to my destination, after I start it to leave, it'll stumble at idle after the first deceleration. For instance when I get to the first stop light. Once I take off, it seems to be okay after that.
All fluids are at appropriate levels, oil pressure while slightly jittery is healthy, temps are okay, vacuum is okay when the engine isn't stumbling.
CEL is back. So I'd bet the ECU wasn't the issue. At least not the main issue.
I had to get to work and I didn't have time to pull the code and poke around with my multimeter. My guess is it's another code 35. I'll post back after work to confirm.
It ran fine but I noticed a high idle, around 1500 rpm as well as a fluttering vacuum. Nothing major but more flutter than "normal".
If the purge valve sticks open, does that mean that excess vapors are entering the intake? If so that'd explain the high idle. Too much fuel.
Can the purge valve have issues with sticking open yet still test okay with a multimeter? Does the ECU know when the valve is open based off its resistance? If so maybe the valve is testing okay, but is having issues with sticking open which throws the CEL.
My new valve will be here early next week so hopefully this solves the issue. If it's not the valve and not the ECU, then I just have to do some harness work.
I like harness work, I can do it inside in my sweats rather than out in the cold freezing my hands off.
