October 22, 200421 yr ok so I'm going to swap MCs on my 88 RX, (its out of the parts 89). anything I should know before I install it? like tips or anything.
October 22, 200421 yr Bleed the system really well afterwards. You might go through a few bottles of fluid (Don't resuse the new fluid that goes through the system), but its worth the cost of wasted fluid to not have air pockets in your brake circuit.
October 22, 200421 yr Author I've always wondered why that was (not re-using the new fluid thats going thru the system) I'm not going to do it as I have 6 new bottles of DOT 4
October 22, 200421 yr You'll need to 'bench bleed' the master cylinder. Take two old male end fittings and cut the lines real short. Then slip on about 5 inches of rubber hose on the hardlines you just cut. Unscrew the fittings from your master cylinder and screw in your new 'bleeders' you just made. Pop the cap off the MC resivour and run the rubber lines directly up into the resivour. Make sure its at the Full mark. I would also suggest using clear tube so you can watch the air bubbles. Now get in the cabin and pump the brakes. Keep pumping untill you see no more air bubbles in the lines. Now quickly remove and replace the normal hardline fittings. Then bleed your brakes at the brake cylinders like you would normily (cross directional patern) and you should have some solid brake pedal action!
October 22, 200421 yr Author its an old (IE off of another car) MC do I still have to bench bleed it?
October 22, 200421 yr its an old (IE off of another car) MC do I still have to bench bleed it? You have to bench bleed it if A) you let it go empty or any air accidently gets introduced into the MC. One of these usually happens when you take the whole thing off the car
October 22, 200421 yr Author arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to?
October 22, 200421 yr arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to? u can get a bleed kit from a parts store. Or just forget bench bleeding and do like I have done...bleen in cat with the lines on...just minimize air exposure.
October 22, 200421 yr arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to? Any male fitting from any part of the car will work. It's really not that hard or big a deal. Hit up a junkyard or even any parts store. It's a pretty common size metric fitting. Just bleeding the crap out of the system at the brake bleeders won't get all the air out of the MC if any gets up in there. I'd say just put it all together and see how the pedal feels. You might not get any air up in there. Just don't let the resivour go dry and try not to let any air seep in through the openings where the lines screw in the side.
March 7, 20215 yr Well done bumping the oldest dated thread on USMB! Lol Edited March 7, 20215 yr by idosubaru
