JWX Posted October 22, 2004 Share Posted October 22, 2004 ok so I'm going to swap MCs on my 88 RX, (its out of the parts 89). anything I should know before I install it? like tips or anything. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted October 22, 2004 Share Posted October 22, 2004 Bleed the system really well afterwards. You might go through a few bottles of fluid (Don't resuse the new fluid that goes through the system), but its worth the cost of wasted fluid to not have air pockets in your brake circuit. 1 Quote Link to comment Share on other sites More sharing options...
JWX Posted October 22, 2004 Author Share Posted October 22, 2004 I've always wondered why that was (not re-using the new fluid thats going thru the system) I'm not going to do it as I have 6 new bottles of DOT 4 Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 22, 2004 Share Posted October 22, 2004 You'll need to 'bench bleed' the master cylinder. Take two old male end fittings and cut the lines real short. Then slip on about 5 inches of rubber hose on the hardlines you just cut. Unscrew the fittings from your master cylinder and screw in your new 'bleeders' you just made. Pop the cap off the MC resivour and run the rubber lines directly up into the resivour. Make sure its at the Full mark. I would also suggest using clear tube so you can watch the air bubbles. Now get in the cabin and pump the brakes. Keep pumping untill you see no more air bubbles in the lines. Now quickly remove and replace the normal hardline fittings. Then bleed your brakes at the brake cylinders like you would normily (cross directional patern) and you should have some solid brake pedal action! Quote Link to comment Share on other sites More sharing options...
JWX Posted October 22, 2004 Author Share Posted October 22, 2004 its an old (IE off of another car) MC do I still have to bench bleed it? Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 22, 2004 Share Posted October 22, 2004 its an old (IE off of another car) MC do I still have to bench bleed it? You have to bench bleed it if A) you let it go empty or any air accidently gets introduced into the MC. One of these usually happens when you take the whole thing off the car Quote Link to comment Share on other sites More sharing options...
JWX Posted October 22, 2004 Author Share Posted October 22, 2004 arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to? Quote Link to comment Share on other sites More sharing options...
WJM Posted October 22, 2004 Share Posted October 22, 2004 arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to? u can get a bleed kit from a parts store. Or just forget bench bleeding and do like I have done...bleen in cat with the lines on...just minimize air exposure. Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 22, 2004 Share Posted October 22, 2004 arggg I don't want to mess up the lines on the parts car what about that bottom fitting? do I have to bleed that one to? Any male fitting from any part of the car will work. It's really not that hard or big a deal. Hit up a junkyard or even any parts store. It's a pretty common size metric fitting. Just bleeding the crap out of the system at the brake bleeders won't get all the air out of the MC if any gets up in there. I'd say just put it all together and see how the pedal feels. You might not get any air up in there. Just don't let the resivour go dry and try not to let any air seep in through the openings where the lines screw in the side. Quote Link to comment Share on other sites More sharing options...
Dbeluscak Posted March 5, 2021 Share Posted March 5, 2021 (edited) Whoops! Wrong post. Edited March 5, 2021 by Dbeluscak Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 7, 2021 Share Posted March 7, 2021 (edited) Well done bumping the oldest dated thread on USMB! Lol Edited March 7, 2021 by idosubaru 1 Quote Link to comment Share on other sites More sharing options...
