wjm, more fuel to defeat detonation?
if wjm does not answer i will
i went 10 psi stock suby injection
to 10psi ms injection
and wow ..... yes more fuel does help infact i was a tiny bit rich in the top end and it would bogg down a bit
till ilifted
as soon as i get mine going again
i can give more infoe and even base fuel and ignition maps
10 psi althogh manged by saab 9000 apc turbo control's
10 psi boost stock mpfi versus 10 psi do it yerself or aftermarket injection setup's
either way for power/money and tunability i would go do.it.yerself. injection
that has a open code base that anyone can ad to or modify
oops nap time :)
i have seen you say this. are you sure? i thought it just retarded the timing when the knock sensor was trigggered. which fuel injection, early, late?
I thought it retarded it as well...but then i played with it some, purposely running too much timing...and I watched as unburned fuel exited the exhaust system and my fuel mileage went to 16 MPGs...then i tuned the timing back to where it was suppoed to be...and I was getting 23 or so...and no more fuel clouds!
Does the same on 85-86 as 87+...note: MPFI/TURBO only tho...as SPFI/CARB doesnt have a knock control system.
Maybe on 87+`s,but 83-86 engine computers have no input from the knock control system and therefore no way of knowing when detonation is occuring.
so whats the limiting factor on the 87+ systems. how much does it do it till. like if you ran normal timing and set it at 20lbs of boost. is the maf sensor the limiting factor? or the fuel pump, not putting out 20 extra lbs of fuel?
i would hope that the er27 responds the same way.
The advantage of the pre 87 is the fact ath you can disable the over boost fuel cut. 87+ its built into the MAF/ECU...and it will cut when 9 PSI or more is held for 10 seconds or so.
BUT...the 87+ has a better knock sensing system, better dizzy, and better ECU to handle the detonation issues when it arises...I have NEVER heard knock on an 87+....but even on STOCK pre 87s i hear it for a split second when turbo spools...then I see a slight fuel cloud. Timing retard/IC/better fuel cures that...but timing tuning is evAr so critical on the pre 87's its not fun at all.
87+...its still critical...but not quite as much...as the reaction and control of the knock is much much better.
I am going to install my GReddy EBC...and play with the fuel cut a little...at 10 psi only tho. Tune on some timing...and see how the engine does.
i agree. the knock sensor is a stand alone unit, that retards the timing with vacc. the early ones relied on the maf almost totaly to know whats goin on.
the vac is advance only. None of the dizzys can retard either electronically or mechanically.
Both units dump fuel. 87+ is better at detecting it than 85-86.
You are wrong on all 3 counts my friend.
All pre 87 turbo distys retard both mechanicly and electronicly.
The "vacuum advance" also serves a pressure retard function.Take a look at the curves in your FSM.
They will all retard electronicly when the knock control unit says to.
Additionaly, they will all advance electronicly at high altitude.
Your unburnt fuel is due to something other than the computer responding to detonation.
Pre 87 engine computers can`t sense detonation directly and therefore can`t respond to it.
(prove me wrong by pointing out the pin#)
They will however enrichen the mixture when positive manifold pressure is sensed or the "full" contacts are closed in the tps.
the 85 to 86 is just a carb disty, so it doesnt have any way of electronicaly retarding the spark. its all centrifical, and vac. i think the knock sensor on old ones, just gave the disty some vac, when it knocked, which just reduced the advance, to somewhere near idle.
Applying vacuum while knocking would advance the spark not retard it.
Knock control units are electronic.That`s why turbo ignition modules have 4 terminals instead of the normal 2.One of the extras is a phase control signal wire from the KCU.
Increases fuel upon detection of knock.
Not what my FSM says.
Take a look at the attached scan of the knock control unit.
There is no connection to the engine computer.
FSM goes on to detail how timing will be retarded up to 10 degrees w/heavy detonation.(in fact, it is part of troubleshooting the KCU)
wjm i hae to say it but your wrong
knock sense is only ignition related on any car
it hears knock it pull s back teh timing until it goes away
tehn waits x amount of time and readvances
unless it hears knok again
btw adding more fuel or in the case of teh stock ecu getting the correct amount of fuel in reduces detonation alot .. i know same boost level same timing amount go from stock ecu to ms controlled injection no knock
when you run lean it has a tendancy to detonate
mostly cause less fuel in the mix the faster what little fuel ignites
more fuel the intake charge is a bit cooler /denser/wetter if that how you want to think of it and the longer it overall takes to light off
at least thats how i have always understood it
and knowing for a fact that with everything else being the same
just adding more/close to correct amount of fuel i was able to run the exact same psi of boost and hear no detonation
for me its hard to explain perhaps if i was more able to express what i think in a better way it would mae sense
but
my mind is such a nightmare for me to untangle i dread what it would belike if i let it lose on the unsuspecting populace :)
