XT6 ??'s
Qman
I need to know if there is a fuel pump relay on these little monsters. It was running and the battery shorted and spent one of the fusible links. I am wondering if it got the relay or the pump. Have spark and runs off of starting fluid.
Thanks!!
According to my FSM, the fuel pump relay is under the center console. Let me describe the picture...
If you are in the drivers seat, with the center console (lower part, in front of the shifter) off. YOu should see 2 groups of 2 relays, one set to the left, and one set to the right. The one on the right and to the top (could be back?) is the fuel pump relay.
