December 15, 200421 yr My 92 loyale has those auto seatbelts and the driver's side is jammed and draining my battery even when the car is off...My question is... Does anyone know how to disconnect the power source for the seatbelts only or possibly what fuse runs them...i am tired of disconnecting my battery every time i park the car!!! And i wore out the hood pull latch inside from popping it so much....please help!!!
December 15, 200421 yr If you do a search on auto seat belts, there was a thread not too long ago about how to get them unjammed. Then you could use them again.
December 15, 200421 yr Author Thank you..but i would really like to just disconnect the power source...so if anyone knows what fuse controls it and or wiring harness please let me know... My 92 loyale has those auto seatbelts and the driver's side is jammed and draining my battery even when the car is off...My question is... Does anyone know how to disconnect the power source for the seatbelts only or possibly what fuse runs them...i am tired of disconnecting my battery every time i park the car!!! And i wore out the hood pull latch inside from popping it so much....please help!!!
December 15, 200421 yr i can tell you the 'brain' of the autobelts is in the truck up underneath between the rear speakers.
December 16, 200421 yr the motor is in the center post (by the front seat hinge) down near the floor. remove the lower trim and you will see the motor. simply disconnect the plug.
December 16, 200421 yr I had a shorted wire in the door switch wire. You have to remove the door panel, look at the bottom aft end.
