wipers only work on hi, dead everwhere else...
I left work today and suddenly my wipers only work on hi, they are completely dead on int and lo... so dead that if I put them on hi and then switch them to lo they will stop in the middle of the window... they worked fine this morning...
just bad connections? in the arm on the tree? what's the most common cause of this?
thanks!
Probably the arm or the little relay thingie under the steering column.
My guess is the column. Never had one of mine go bad, but there is a little black box on the drivers side kick panel that says WIPER CONTROL on it. Hard to miss really...
I have a GL-10 one laying around, but sorry no spare GL ones for you :banghead:
Probably REALLY cheap a U-Pull-It, $2 maybe??
cool, I'm hoping it's just a relay or something... I'll tear my kick-panel apart and replace the little box...
*heads to u-pull-it in a few*
it must not be too hard to miss because I don't see it anywhere... I tore off all the panels under the column and don't see any wiper relays or control box... I see what looks like a main computer box, and a cruise control box, but nothing with the wipers... lots of wires and connectors though...
I also can't believe I stumped the rest of the board with this problem... go me! 29 views and nobody knows for sure... guess I'll take the tree switch apart and check there for bad connections...
anybody else know what this problem could be? I'd really like to take a road trip, an hour ago...
I think there is a seperate control box for the low speed control but it may be internal to the wiper motor. How many wires tie to the motor?
there are 4 wires to the motor... (c is the connector clip)
1 2
3 4
c
checking the voltage at each switch setting:
hi - #1 12v & #2 12v
lo - #1 12v & #4 9v
int - #1 12v & #4 12v
no voltage on #3, so maybe it's a ground or something... *shrug*
does that look right? seems like there's power getting to the motor... I'm gonna guess that it's all internal to the wiper motor at this point... guess I'll replace that...
Since you are getting 9 volts at pin 4 in the low position then it seems that the motor should be working on low speed. It would be good to know which direction the voltage is being supplied from. The pin may be a return to the control box and the problem is in there. I wonder about this because you have 12 volts at pin 4 and it works ok so it seems to me that problem may be between the switch and the control box.
yeah, I tried another wiper motor from bajavwsoobnut (thanks for the wiper motor!) and it did the same thing... so it's somewhere in-between... I'll probably just see if richie has some time to look at it one of these saturdays, since I'd like him to check out my vent/4wd vacuum problem anyways... (:
Spiffy,
The control module you are looking for is mounted close to the edge
of the trim panel that is above your knees when in the drivers seat.
Same panel that must be lowered to see the ECU
(Kick panel - at least to my feeble mind, is the panel to the left of your feet when seated?)
The plastic control module is gray or black in color.
Maybe the plug has come out of it, this can happen when removing the trim panel.
As for your 4wd / vent problem, under the hood, on the shelf behind
the passenger side strut is a white vacuum storage canister.
Check the line to the canister
from the intake manifold and the one leaving going to the 4wd solenoids.
These are mounted on the shelf behind the driverside strut.
Both systems share this vacuum.
Hope this helps.
  • 1 month later...
I still haven't been able to locate this module... I even got a replacement one (it's grey) from XSNRG to replace it with... I just don't see it under my dash, black or grey...
form left to right I see against the left wall a cruise control module, then a huge white connector with lots of plugs passing through it (basically behind the fusebox), then the ecu in the middle under the column, and then a cruise control cylinder that's attached to the gas pedal, then the heater controls on the center console...
[cruise module] [huge white connector] [silver ecu] [cruise mech] [vents]
can somebody be really, really specific with describing the location of the WIPER CONTROL module?
thanks!
The control module you are looking for is mounted close to the edge of the trim panel that is above your knees when in the drivers seat. Same panel that must be lowered to see the ECU
Something that's real easy to check...
Find a short jumper cable and run another ground to the wiper motor cable. IIRC, it's a small black/yellow wire.
This has fixed my herky-jerky wipers on int, and a couple other people that I know of.
ok, so I'm starting to think that my car doesn't have this WIPER CONTROL unit in it... I'd like some more people to confirm or deny its existance before I give up hope and rip my steering wheel off to replace my switch assembly...
I have a manual for an '88 that I will check an let you know what I find. I think there must be a module somewhere since it has to control the delay circuit also.
awesome, thanks!
I figure I'm totally blind, or it's in a different spot for my year...
so you had the trim panel down that
has a a heater duct connected to it
and it is not mounted on the lip facing you on the top side?
funny I have 87's and an 89 all have it in this location
well skip maybe there is none on his , [ missing] a few months ago you told me that my 1986 fwd a/t sedan is not spfi , which it is ,and they did make them in 86 only in a sedan and only in fwd ,
According to my manual the wiper intermittant unit should be behind the dash around the heater control area or above the radio area. Look for a blue 8 pin connector. Sorry about not getting back sooner on this.
Spiffy,
If you still have trouble locating the module
or would like to test the switch before tearing the
st. wheel covers off.
It's connector is a 17 pin connector black in color
under the st.. column.
You can stick a test lights probe into the wiring of the
connector, having the other side of the test light grounded.
Alternatively you can stick a pin through the insulation
and test for voltage on it
The 89 FSM shows the Green with white tracer wire
getting +12 volts in the low speed position.
Note: It shows this wire is a direct connection to the
wiper motor and does not go to the control module.
Meaning that possibly the module is not the problem.
I have a scan of the wiper control system ,
please email me if you would like a copy.
it's true... after you mentioned it I looked on the back of that panel that the vent hooks to and I don't even see a spot that it could mount to... no screw holes or slots or obviously vacant space...
since I think I need to replace my vent controls I'll check for it back there when I get a good vent control unit to swap in...
Sorry for the mis info on the module placement,
I apologize.
Goes to show all is not the same in the land of the
Plieades and learning something every day is good.
But
while you have the panel down
why not test the switch?
If you want to test the wiring to the motor
you could put a jumper lead
from a 12v source to the pin you stick in the wire
for testing
On your vent control problem
make sure the white cannister
on the shelf behind the pass. side strut tower
has it's vacuun lines connected and operational.
________________________________________________
I have said and misinformed you enough
I will let Glenn take it from here
Good luck hope you get it fixed
well it turned out to be a bad switch...
thanks to Flowmastered87GL for being the first to suspect it and Skip for supplying the wiring diagram that showed it was the switch... thanks to XSNRG for the replacement column switch assembly, and bajavwnsoobnut for the wiper motor (which I didn't end up needing, yet)...
and while I was under there I figured out part of my vent problem... (:
thanks!
