EA82Turbo Posted January 9, 2005 Share Posted January 9, 2005 Hi, My EA82T has an Vane Air Flow Sensor (VAF), which looks like it would restrict air flow. What are my options when changing this sensor? Can I use a MAF or MAP? What is involved in the swap? Cheers Hayden Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted January 10, 2005 Share Posted January 10, 2005 Hi, My EA82T has an Vane Air Flow Sensor (VAF), which looks like it would restrict air flow. What are my options when changing this sensor? Can I use a MAF or MAP? What is involved in the swap? Cheers Hayden It looks like it is restrictive by its makeup but do you know for sure that it is more restrictive than a MAF (or MAP) sensored car? I say this because maybe a day or two ago, I was reading this article: http://www.autospeed.com/cms/A_2055/article.html I can't access the whole article now for some darn reason. ???? Anyway, I remember reading a sub-section that was talking about vane air flow sensors vs Hot Wire Maf sensors. It stated that the vane air flow sensors causing more restriction is a fallacy/myth/just plain false. They even stated that some vane air flow sensors flow better than comparable maf sensors and they stated why. I saved that link in my yahoo mail but now I can't access the whole article to post up the points it made. Sorry! Quote Link to comment Share on other sites More sharing options...
EA82Turbo Posted January 10, 2005 Author Share Posted January 10, 2005 Thanks for your reply. Had a look at the link but can't get to the whole article without being a member. Maybe vane is OK???? I don't know, MAF or MAP looks better but maybe they aren't as accurate. Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted January 10, 2005 Share Posted January 10, 2005 Ok, I purchased access to Autospeed. I keep ending up back at that site reading up on some information about something or another anyways. Here's what I remembered reading previously. " Vane Airflow Meters - Not What They Seem! There are a few other things to note about vane airflow meters: (1) Unlike a hot wire design, the vane airflow meter measures volume airflow, not mass. It's mass which is important, and so a temp sensor is included in the airflow meter. With airflow volume and temperature available, mass can be calculated. (Atmospheric pressure? - for really accurate calculations, it's needed as well!) (2) The insides of the meter - both the mechanicals and electricals - are carefully designed so that the meter is very sensitive around low loads, where good driveability requires a high resolution. This means that, strictly speaking, the output signal is not directly proportional to combustion air intake volume. (3) It is a complete and utter fallacy that vane airflow meters are restrictive. In fact, measurement shows that a large vane airflow meter poses less full-load restriction than a similar sized hotwire airflow meter. (We'll cover this intriguing point in more detail another time.)" The article goes on to talk about a lot of other different stuff about air/fuel ratios and the vane air flow sensor but I'll stop here. Quote Link to comment Share on other sites More sharing options...
Vanislru Posted January 10, 2005 Share Posted January 10, 2005 The vane type MAF rules! this means you have an 86 or older computer and the overboost sol. that can be disssabled so no fuel cut. My car in the sig has that vane type maf and I don't think it's restrictive in any way, unlike the stock pipes it had, or the air intake silencer, or the stock filter, etc. Quote Link to comment Share on other sites More sharing options...
Scoobaroo Posted January 10, 2005 Share Posted January 10, 2005 Vane type sensors have a "clock spring" return spring. Very little resistance at low speeds, more resistance at higher speeds. Under high flow conditions, the vane is slammed wide open anyway. Almost zero airflow resistance under wide open throttle. Quote Link to comment Share on other sites More sharing options...
Levysoobie Posted December 20, 2009 Share Posted December 20, 2009 i've got a MAF that is with the little wire's in them and it does'nt work could i put a vane insted of the original ? will it work? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 20, 2009 Share Posted December 20, 2009 i've got a MAF that is with the little wire's in them and it does'nt work could i put a vane insted of the original ? will it work? No - and please start a new thread rather than dredging one up from 4 years ago. GD Quote Link to comment Share on other sites More sharing options...
rxleone Posted December 22, 2009 Share Posted December 22, 2009 No - and please start a new thread rather than dredging one up from 4 years ago. GD Maybe we should be rewarding him for using the search bar instead of making new threads every five minutes like some other clowns on here do? These are the questions Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 22, 2009 Share Posted December 22, 2009 Maybe we should be rewarding him for using the search bar instead of making new threads every five minutes like some other clowns on here do? These are the questions Yeah - but it never end's up working because people come along and start answering the question that was posed 4 years back because they pay no attention to the thread date and it get all kinds of screwed up and confused. Better to have a FAQ and just put up with people who repost common questions - and scorn those that dig up stuff that's only 25% related to their question. GD Quote Link to comment Share on other sites More sharing options...
