January 19, 200521 yr Parting out an XT6 here. Wondering if the rear axles are any different or better. Are they wheely poping power? Thx !_!
January 19, 200521 yr i was trying to ask the same Q months ago...just want to know if they're beefy-er or not
January 19, 200521 yr as I understand, XT6 rear axles are of the LSD variety... but not sure what gearing, i.e. 3.70 or 3.90 also not sure if they're any "beefier", but 4wd Subie rearends are pretty bulletproof in the first place so..... hth
January 19, 200521 yr Author as I understand, XT6 rear axles are of the LSD variety... but not sure what gearing, i.e. 3.70 or 3.90 also not sure if they're any "beefier", but 4wd Subie rearends are pretty bulletproof in the first place so..... hth This is an XT6 with no rear LSD. They dont LOOK any better but looks can be different than reality. I guess if anything they will just be some trail parts
January 19, 200521 yr Author The axles are stronger IIRC and the differential is the same as other subes. Just the fronts? Or rear and front? Cuz the fronts look beefy compared to normal EA82 axles. Rears look the same. Maybe previouse owner had rears replaced with cheaper EA82 rear axle?
January 19, 200521 yr fronts might have a different spline count... don't remember. I do remember reading about it in a post around here somewhere though... and on the LSD in XT6 comment... very few xt6's are equipped with an LSD, most of the people over at xt6.net have never even seen one
January 19, 200521 yr as I understand, XT6 rear axles are of the LSD variety... but not sure what gearing, i.e. 3.70 or 3.90 also not sure if they're any "beefier", but 4wd Subie rearends are pretty bulletproof in the first place so..... hth These cars are independent suspension front and rear, the axles are seperate from the differentials, its the Diff that has the LSD, the axles transmit the power from the diff to the wheels.
January 19, 200521 yr Just the fronts? Or rear and front? Cuz the fronts look beefy compared to normal EA82 axles. Rears look the same. Maybe previouse owner had rears replaced with cheaper EA82 rear axle? yeah i have had xt6 and gl front axles next to each other...they are bigger. but i too still have not compared the rear axles
