August 23, 200322 yr im kind of new in the subbie scene. I got an XT6 for $1 :-) and want to put a JDM WRX STi engine and tranny in it. Is this possable? -John
August 23, 200322 yr it fits. just go for it. theres pleanty of info already on here. check the posts. svx in a hatch will cover some basic info. i bet you would need a 1.8 xt crossmember.
August 24, 200322 yr Anything is possible - but you will need to adapt not only the engine to fit the car, but also replace the tranny, and you may have to change the length of the axles. a JDM engine won't help you much since you will need the entire wireing harness as well - ECU, all sensors, etc. Find a wrecked STi and use that. I wouldn't mess with a JDM anything, since they know they are getting rid of the motor after 50,000. The oil hasn't been changed cause they don't care. If you do - rebuild the engine carfully. Your money would better be spent on a complete, wrecked donor car. Saves time, and sanity. GD
August 24, 200322 yr best of all this link given to me by someone doing the same thing http://www.kennedyeng.com/
August 27, 200322 yr Author i would be getting a JDM ful swap (Engine tranny ecu) wouldnt a wiring harness out of a USDM WRX work?
August 28, 200322 yr NO. think: JDM vs USDM The JDM stuff you are getting is STi, the USDM is WRX stuff. Nope. BUT: you could find a donor WRX and use it easy'r than getting an STi me thinks.........just get the whole package, its much easy'r. The things i did, ive always had the whole package nearby, so it got done easily.
August 28, 200322 yr Originally posted by STiXT6 im kind of new in the subbie scene. I got an XT6 for $1 :-) and want to put a JDM WRX STi engine and tranny in it. Is this possable? -John Hello John, Ask these guys: http://xt.zybx.com/index.htm Or these guys: http://autos.groups.yahoo.com/group/xt6/ They probably can give you a lot of insight on what you need to do to get this to work.
