January 28, 200521 yr How difficult is it to replace the front rotors on a 99 Outback? Should this be left for my trusty mechanic or is it somewhat simplistic?
January 28, 200521 yr Piece o' cake. If you've done it on any other car, you'll have no trouble. If not, get the Haynes or factory shop manual, and go to it.
January 28, 200521 yr first time i did brakes i thought "oh my nuts i can't believe i've paid people exhorbitant amount of money to do this". suffer the learning curve now and thank yourself for the rest of your life. this board will be a great resource. i second the haynes manual or a factory service manual if you're looking to learn more and do other maintenance yourself.
February 1, 200521 yr Author My mechanic told me that it would cost $175.00 labor to replace the front rotors because they need pulled ( not sure what that means ) vs. the rear ( cost $60 ) because they don't need pulled. Sorry I'm such a novice regarding these things, but is the process the same to remove the front and back rotors? Should it cost that much more to pull the front vs. the rear? I'd appreciate any help. Thanks Kevin
February 1, 200521 yr $175 for the front, just for labor? It's not going to take more than 30 minutes a wheel to replace rotors, & replace the pads. What's his hourly shop rate? FYI, A set of new OEM front rotors cost me about $90. (about $45 each)
February 1, 200521 yr My mechanic told me that it would cost $175.00 labor to replace the front rotors because they need pulled ( not sure what that means ) vs. the rear ( cost $60 ) because they don't need pulled. Sorry I'm such a novice regarding these things, but is the process the same to remove the front and back rotors? Should it cost that much more to pull the front vs. the rear? I'd appreciate any help. Thanks Kevin I'd be a little concerned about that mechanic.....the front rotors do not need to be "pulled" (or un-bolted). If you simply remove the lower of the two caliper slider/retainer bolts, the caliper (with brake pads still inside it) will tilt upward away from the rotor, then the rotor simply slides off of the lug nut studs. The REAR brake rotors, on the other hand, are a different story. They DO require unbolting from the hub to remove them. This is a more complicated job. The rear rotors are actually a "rotor and hat" assembly (for lack of a better term); they are a brake rotor with a brake "drum" made into the inside of them. The brake drum is for the parking brake.
February 1, 200521 yr in general no, i don't see a reason for such a large gap in price for front/rear. but i don't know the OBS very well. just got one, but haven't looked at the brakes yet. do you really NEED 4 disk rotors brand new? if taken care of properly i've had rotors last a REALLY long time. i don't even have them turned, i just make sure to replace the pads early. at 200,000 miles i decided to replace my rotors for good measure, though there was nothing wrong with them. one of the news ones was warped!! had to return it.
April 10, 200521 yr the lug stud holes will be identical, not sure about fitment though (width, size, etc). seems the wrx rotors would be larger in some way. check some online part stores like thepartsbin.com or others and see if they post sizes with the part numbers and pictures.
April 11, 200521 yr Some cars need to have the hub pulled to remove "captive" rotors. Sure ain't that way on a '91. Doubt if it's like that on yours. A nice setup Subaru has. Find a better mechanic (more honest). Just have to remove the caliper. About 10 mins. work max. As far as rotors, I never had a problem with Autozone/ Advance Chinese rotors, but they do seem to wear fast. All the better for rustbelt conditions to prevent pitting.
April 11, 200520 yr Rotors on the '99 OB aren't captive. Just get the caliper out of the way, and they come right off. I used the cheap rotors and pads from Advance Auto (Wear Ever Silver), because they were in stock and I needed them right away. They work just as well as anything else I've used (Brembo, PBR) for my style of driving. Cost was less than $180 for pads and rotors for all four wheels.
April 12, 200520 yr Just for others info. I had a heck of a time getting the correct rotors for both my 1996 Legacy LS Wagon and my 2001 Outback. I got them from Advanced Auto and AutoZone and no one seems to have the correct size, even though their system says they fit. Just a word to the wise to measure the diameter of your old rotors and compare them to the replacements before you take everything apart. I ended up going to the dealer for the parts. Noel
April 12, 200520 yr I need to replace my front rotors (warped apparently?!). Canadian Tire quoted me $93 each!!! Someone I know who works for a Saturn dealership may be able to find me cheaper ones (wholesale price). Just for others info. I had a heck of a time getting the correct rotors for both my 1996 Legacy LS Wagon and my 2001 Outback. I got them from Advanced Auto and AutoZone and no one seems to have the correct size, even though their system says they fit. Just a word to the wise to measure the diameter of your old rotors and compare them to the replacements before you take everything apart. I ended up going to the dealer for the parts. Noel
