February 7, 200521 yr Will it fit under the hood, with hood scoop, and is it too large for an 1.8 ltr engine? Or is a regular (u.s.) wrx type sufficient. What are the plumbing problems?
February 7, 200521 yr Do a search for WRX intercoolers. Many people have put on a WRX intercooler, and it seems to be about the right size and design for the EA82T. Garner, Calebz, Subarutex, and WJM just to name a few. I don't know what the difference is between that and an STI one, though I assume the STI is larger.
February 8, 200521 yr i just run a wrx intercooler and it works great. A sti intercooler might work better but they are alot more $$$. the $$$ is the resson i just got the wrx but i was amazed how much power it added
February 8, 200521 yr The STI is larger and overall better flow. On an EA82 the WRX is a great addition and all you need unless you got into wicked high boost.
February 9, 200521 yr The STI is larger and overall better flow. On an EA82 the WRX is a great addition and all you need unless you got into wicked high boost. Agreed. The STi unit is larger by about 10%~15%...or so. The y-pipe is all metal and the core is larger....aka wider. BOTH the WRX and STi units will fit under the hood.
