Engine refit EA82 to EA81
Is it possible to fit an EA81 into an 83 DL wagon? If so are there an modifcation or parts issues? The engine that is currently fitted is an EA82.
Sure, it'll fit :) Shouldnt be to bad of a motor swap too seeing how the EA81 is carbed. If your EA82 is SPFI you might look into the SPFI upgrade onto the EA81 engine. There is a write up here on it. http://www.ultimatesubaru.org/forum/showthread.php?t=28620&highlight=ea81+spfi+conversion
Glad to have you here; but you might find some local help at http://www.ausubaru.com . They have a forums section and such. Might find someone in your area willing to help!
Good luck
Thanks for the good info. The car came standard in 83 with the EA82. I will look into it further and check out the aus site. I will let you know how I go,
Cheers from down under.
Scano.
I think they got the EA82 styled ones earlier down under
You sure about the whole ea82 in an 83 bit???
We sure don't have ea82 styles in 83 in New Zealand, and we usually get the same models as Australia....
