ej to ea82t flywheel
does anybody know if an ej series flywheel has the same bolt pattern as a ea series flywheel?
it does not. Slightly different.
how differnt is it? do you think it could be "Adjusted" to fit that pattern thanks Ty
Yes, has been done. Jay
Ditto.
the ej flywheel holes are farther outward from the center of the flywheel than the ea series flywheel holes, by about 3/8 of an inch or something like that.
~Josh~
is that the only differnce? if so that would be great!
The Ej Flywheels have Equally spaced bolt holes, the EA flywheels have one bolt hole that is not equally spaced from the rest.
should have said that.................i knew that..........
