quebechatch Posted February 28, 2005 Share Posted February 28, 2005 Tired of replacing suspension arms? I am. go check out the ones that I made this weekend, they are in the latest pictures in the gallery right now. Quote Link to comment Share on other sites More sharing options...
bushbasher Posted February 28, 2005 Share Posted February 28, 2005 Looks Beefy! What will you use for bushings? Quote Link to comment Share on other sites More sharing options...
singletrack Posted February 28, 2005 Share Posted February 28, 2005 Those are sweet! Good work. Quote Link to comment Share on other sites More sharing options...
ballitch Posted February 28, 2005 Share Posted February 28, 2005 is that like 1/8 inch tubing for those, and how was the camber/caster/toe in affected, or are you just that good and copied it perfectly? ~Josh~ Quote Link to comment Share on other sites More sharing options...
MorganM Posted February 28, 2005 Share Posted February 28, 2005 Here is a direct link to your gallery: http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=2955 Quote Link to comment Share on other sites More sharing options...
diluded000 Posted February 28, 2005 Share Posted February 28, 2005 Tired of replacing suspension arms? I am. go check out the ones that I made this weekend, they are in the latest pictures in the gallery right now. I have been thinking about doing this myself. My shop-fabricated 3" lift makes the front tires a bit closer to the car at the bottom than at the top. (toe in?) Shorter or adjustable suspension arms would help things, but I don't know if my little welder would do the job. If you don't mind, I would like to hit you up for some specific questions: What kind of welder did you use? Did you use a shop-press to install the bushings? Is a part available for where the ball joint is attached, or is that cut out of he factory suspension arm? Any shop tips on fabricating one of these would be appreciated. - James B Quote Link to comment Share on other sites More sharing options...
archemitis Posted February 28, 2005 Share Posted February 28, 2005 unless thats solid bar stock... looks like = or less strong than stock. Quote Link to comment Share on other sites More sharing options...
bushbasher Posted February 28, 2005 Share Posted February 28, 2005 unless thats solid bar stock... looks like = or less strong than stock. that is far stronger than stock. The stock suspension arm is made of stamped sheetmetal, open on the bottom, with a single brace spot welded on, and about an inch of weld holding the bushing race on. Dimensional strength increases much more with diameter than with thickness. This piece is thicker than stock, has larger diamater tubing, and includes a triangle shape unlike stock which is just v shaped. Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 1, 2005 Author Share Posted March 1, 2005 Looks Beefy! What will you use for bushings? Bushing are from honda civic 88 to 91 model year, I could give the NAPA part number tomorrow if you'd like Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 1, 2005 Author Share Posted March 1, 2005 is that like 1/8 inch tubing for those, and how was the camber/caster/toe in affected, or are you just that good and copied it perfectly My suspension arms are actually about 2'' longer than the originals(I use loyale cv shafts which are longer and lenghtened tie rods) camber is at 0 degree and the angle of the arms are not the same to give me about 1" more of wheelbase so the tires won't rub in cowl dash anymore. It might not work the same for everybody I have made me own lift kit its 4" subframe lift and 1" more to the suspension. the tubing is 1/8 inch. Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 1, 2005 Author Share Posted March 1, 2005 I have been thinking about doing this myself. My shop-fabricated 3" lift makes the front tires a bit closer to the car at the bottom than at the top. (toe in?) Shorter or adjustable suspension arms would help things, but I don't know if my little welder would do the job. If you don't mind, I would like to hit you up for some specific questions: What kind of welder did you use? Did you use a shop-press to install the bushings? Is a part available for where the ball joint is attached, or is that cut out of he factory suspension arm? Any shop tips on fabricating one of these would be appreciated. - James B I used 250 amps miller mig welder I have used a press for the bushings, but maybe a big C clamp would do the job. I've used a plasma cutter to cut the ball joints holes from the original arms. feel free to ask any other questions. Quote Link to comment Share on other sites More sharing options...
monstaru Posted March 1, 2005 Share Posted March 1, 2005 i only have one question.....what are you going to do to the back? Quote Link to comment Share on other sites More sharing options...
slipspeedy Posted March 1, 2005 Share Posted March 1, 2005 when are they for sale:brow: Quote Link to comment Share on other sites More sharing options...
bushbasher Posted March 1, 2005 Share Posted March 1, 2005 Bushing are from honda civic 88 to 91 model year, I could give the NAPA part number tomorrow if you'd like That would be cool. what size tube are you squeezing them into? Quote Link to comment Share on other sites More sharing options...
ballitch Posted March 1, 2005 Share Posted March 1, 2005 i know i would buy some, the stock pieces are very breakable, and some heavy duty lower A-arms would fit the bill just right. not to mention if you could get it to be darn near stock spec. ~Josh~ Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 1, 2005 Author Share Posted March 1, 2005 i only have one question.....what are you going to do to the back? I Have lot's of ideas, but I don't know if I have the time and money to do it. I'll keep informed. Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 1, 2005 Author Share Posted March 1, 2005 That would be cool. what size tube are you squeezing them into? Let get back to you on this, it was a piece of stainless steel that I found in my friend shop and the bushings fitted perfect in it. I don't know if it's a standard size? Quote Link to comment Share on other sites More sharing options...
quebechatch Posted March 2, 2005 Author Share Posted March 2, 2005 That would be cool. what size tube are you squeezing them into? the tube is 1" 1/2 outside diameter, and it's the wall is 3/32 thick. The bushing part number at NAPA is 267-3491 Good luck! Quote Link to comment Share on other sites More sharing options...
