March 17, 200521 yr well I've put XT6 rear trailing arms onto an EA82 GL wagon so I don't see why the XT4 would be any different...
March 17, 200521 yr the XT will have tabs for the rear sway bar, but the gl won't so if your going from the XT to the GL its all good, but the other way around you will loose those brackets
March 18, 200521 yr Author the XT will have tabs for the rear sway bar, but the gl won't so if your going from the XT to the GL its all good, but the other way around you will loose those brackets Cool, thats part of the reason I asked. I have "bad" bushings on my rear trailing arms. Found an XT4 in the jy with sway bar, figured it might be worth a swap...
