April 8, 200520 yr what do you guys do to at least keep the amount of mud down a little that gets on the motor. it seems every time i go out mudding my motor is just chunky with mud. i still haev the stock skid plate, and those stock little little things on each side as well but they dont seem to do much good. so what setups if any do you guys have
April 8, 200520 yr on your motor its not really an issue, but keep your radiator clear, as long as you check your rad when you are done and you arn't over heating i wouldn't worry about it.
April 9, 200520 yr Just wash it off when you get back and it'll be fine. Realistically, adding skidplates will not stop the influx of mud. Rather, it will hold the mud in there even more.
April 9, 200520 yr Author ok, i was figuring it running a little hot was because of the motor pretty much being insulated from all that mud, i was having some running hot issues last night so i sprayed the hell outta the motor and rad, still seems to be runnign hot this morning siting right below the red. think i really need to pull out that ac rad, it seems like it holds in too much mud in it never really thought of it that way snowman, havent really owned many 4wd that i go mudding with so im new in a way to the whole more serious mudding thing
April 9, 200520 yr If you want to keep the mud off either: 1. drive in the water more, or 2. drive on the street:lol:
April 10, 200520 yr Author hey northguy, #2 just isnt gonna happen !!!!!!!lol figured out what my cooling problem was yesterday, i had taken the ac radiator thing off yesterday and found that even after i had sprayed the crap outta it it was still completely clogged with mud, it was also packed in between it and the radiator, and the rad was completelt packed with it. left the ac rad off and sprayed the rad down real well and now it runs like an iceberg, decided to leave my grill out for now since it makes cleaning the rad so much easier. to help keep it cool if it starts to run hotter i had wired the electric fan up to a toggle switch, so i got that and the stock engine controlled fan
