April 12, 200520 yr I have a 2000 outback that is not starting. I just purchased a new battery for it so I know it isn't the battery that's the problem. When I go to start it I turn the key and all I hear is a click, but the engine doesn't turn over. Sometimes I have to turn the turn 40-90 times before the engine will turn over. I don't have any idea what it could be. Does anyone have any suggestions? Thanks! -kyle-
April 12, 200520 yr The problem is the solenoid contacts inside the starter. The click is the solenoid engaging, but since the contacts in the starter are arced, the starter won't kick in.
April 12, 200520 yr Author The problem is the solenoid contacts inside the starter. The click is the solenoid engaging, but since the contacts in the starter are arced, the starter won't kick in. How do I take off the solenoid? What can I do?
April 12, 200520 yr You'd need to remove the starter first. Might be easiest to have it replaced with a new one (or rebuilt?). How do I take off the solenoid? What can I do?
April 12, 200520 yr Author You'd need to remove the starter first. Might be easiest to have it replaced with a new one (or rebuilt?). How difficult is it to remove the starter and how long should it take to remove? I was wondering if there are other parts that have to be removed before I can even get to the starter.
April 13, 200520 yr Easy job 30 minutes and you should have it off! 1) Disconnect the negative battery cable 2) Disconnect the positive cable from the starter 12mm nut I think 3) Pull the other starter wire from the starter terminal 4) Remove the bottom starter nut 15 or 17 mm. A 6" extension and socket work well. 5) Remove the top starter mount nut and bolt 6) Remove the Starter. Take it to the local auto parts or starter rebuild shop and have them test it. Less time to install it!
April 13, 200520 yr Author Easy job 30 minutes and you should have it off! 1) Disconnect the negative battery cable 2) Disconnect the positive cable from the starter 12mm nut I think 3) Pull the other starter wire from the starter terminal 4) Remove the bottom starter nut 15 or 17 mm. A 6" extension and socket work well. 5) Remove the top starter mount nut and bolt 6) Remove the Starter. Take it to the local auto parts or starter rebuild shop and have them test it. Less time to install it! Wow! That sounds easier than it probably will be for me. Thank you I appreciate all the help. If there are any more suggestions I am all ears.
April 13, 200520 yr If you need a starter and are not in a rush, I have both used (auto trans and Manual trans starters. $40 shipped Fedex 2Day. Larry
April 13, 200520 yr if you feel ambitious and want to try and fix it yourself (cheaper), here's a post with a link to .doc that shows the insides and what would likely need to be replaced. disclaimer* This shows an old gen starter, but I would presume they're all about the same anyway. http://www.ultimatesubaru.org/forum/showpost.php?p=19281&postcount=91
April 13, 200520 yr Author if you feel ambitious and want to try and fix it yourself (cheaper), here's a post with a link to .doc that shows the insides and what would likely need to be replaced. disclaimer* This shows an old gen starter, but I would presume they're all about the same anyway. http://www.ultimatesubaru.org/forum/showpost.php?p=19281&postcount=91 Thanks for the link and the pics. If I decided to try to fix it would I need to lift the suby off the ground with a hydraulic lift or could I take it off throught the top of the engine? My email is boysoccer3@yahoo.com, how much would it be to buy one of your used starters?
April 13, 200520 yr The starter should be right there on the top. Whenever I see some GM/Ford/whatever guy crawling under his car to get to the starter, I just have to laugh.
April 14, 200520 yr I love your enthusiasm, but if you don't know what a starter looks like to find it, you probably have no business tearing one apart.
April 14, 200520 yr Author I love your enthusiasm, but if you don't know what a starter looks like to find it, you probably have no business tearing one apart. I didn't know what a starter looked like until someone posted a link with pics! I do think that I am going to give it a shot though. I have school until Wednesday next week and then I will have a little free time. It was mentioned that for someone who know what they are doing it would take 30 minutes to remove the starter. Is this correct? If you have any pointers I would appreciate it.
April 14, 200520 yr I didn't know what a starter looked like until someone posted a link with pics! I do think that I am going to give it a shot though. I have school until Wednesday next week and then I will have a little free time. It was mentioned that for someone who know what they are doing it would take 30 minutes to remove the starter. Is this correct? If you have any pointers I would appreciate it. I would say 15 minutes if your tools are ready : two bolts and two electrical connectors. One you just pull off and the other you unbolt. Speaking of that last connector ( the main one coming directly from the battery), disconnect the battery before touching it if you dont want your wrench to decome a welder.
April 15, 200520 yr The bottom bolt can be a bear. At least, it wasn't easy on my '96, maybe yours is different. If you have the new starter, look that one over and you'll know a bit more when you take the old one out. Good Luck
April 15, 200520 yr The bottom bolt can be a bear. At least, it wasn't easy on my '96, maybe yours is different. I second that! Last month I ended up putting the car on ramps and attacking that bottom bolt from underneath the car, a '95 Legacy. But, all in all, it's a pretty easy repair.
April 15, 200520 yr I started with the car on ramps, as soon as I spotted that bottom bolt before I got going on the job. Sometimes it pays being on the bottom!
