I do something Funny ......Solution ???
Since my owner is busy
i've decided to ask this question myself
my owner asked before about a 'cutout' kind of feel to me
and others said to check the fuel pump connection
it was loose {not me ! just the pump}
and seemed to get better for a while
but i do seem to have problems with the same thing
or something similar .....
when i was being driven to work this morning
i had a very bad 'cutout' feel
and than i had a bad smell ....
kind of a burnt kind of smell
or a hot kind of smell
it wasn't there before the cutout
and it seemed my owner could make it better
if he let off the gas, than gave me gas a little slower....
does this make any sense ???
i want to drive good !!
i want to make my owner happy !!!
please help !!
If carbed I'd say it was the fuel pump/filter - I had mine do "cutouts" where I would be driving along, the engine would stop firing, then it would magically come back - ended up being a bad fuel pump - I would imagine that a FI car could give similar symptoms if the fuel system was obstructed in some way.
The fact that easy use of the throttle helps the problem makes me think this is very likely.
Regardless, if it hasn't had the fuel filter replaced recently, I would do so.
I don't know about the smell - perhaps the fuel pump relay has issues??
I'm SPFI
and have a new fuel filter
and most of a tune up
plugs, cap, rotor, wires, timing belt
my owner still has yet to do my tranny oil :|
soon though i hope !
i also seem to make a different noise.
almost like one of my cylinders isn't firing
but i'm not sure
and when my owner opened my hood
the funny smell was not there
but it was still in my cabin
does this help at all ??
it was loose
Is your pump connection(s) loose again?
Was it 'properly' fixed last time?
my owner hasn't looked yet today
when he put in back in last time
it seemed to fit pretty good
i'll have him check again after he gets off work
would that account for my smell ?
Also, have him check your throttle position sensor. I've found them with a "worn" spot in the range where they sit during cruise and normal driving. It sends an intermittant signal and the ECU thinks the position has changed or there is no signal. So, you get a stuttering kind of feeling.
that sounds like it may be something that he will have to look into
'stuttering' is exactly how it feels
Did owner eat curry the day before.. would explain smell in cabin?!?!?!
haha
he didn't
but probably wanted to .....
my smell was definetly a car smell of some sort
hot or burnt or something
ok
so i dug around a little last night
seemed better after i put it all back together
ran fine this morning, for about 25 minutes .....
than started to do the exact same thing :{
so
i think i'm going to do the pump
but the napa part number for the ford pump
napa here {canada} says thats not there part number
but that the 'p' code is a carter part number
i phone around .... 200 bucks !!!!
i think i'll just get a used one from JY
but as i'm totally broke rump roast
i don't know when that will be :{
i'll dig around a little more tonight and see if i can find anything else
might an o2 sensor cause something like this ??
as an after thought,
would a fuel pressure regulator do something like this ?
when i had my little bronco
the pressure reg died
and the thing ran very much like this thing is running right now
do they ever go bad on subes ?
is it something i should look at ??
Tell that parts guy to get to work. If the part number don't work then tell him you want an in-line fuel pump for a Ford F150 EFI early 90's. There should be a few to choose from and ask for the cheap one! :)
FPR is a possibility I spose. I've never had one go out so I dunno the symtoms. Your's will be located on the side of your throttle body assembly there. One fuel line comes in and the out going fuel line comes directly off the FPR. Never swaped just an FPR; might be worth your time to just swap in a whole top of a throttle body assembly and that way you'll be replacing IAC, FPR, TPS, and fuel injector all at the same time.
damn good idea !!!
125 used from wreckers
do-able ...
and i think i'm going to have to go down to napa and be a pain in the rump roast
no one is of help when i'm on the phone
any idea on engine size for the ford ?
thats the questions that keeps comming up from all the parts stores
damn good idea !!!
do-able ...
302 V8
ok
i finally figured something out
i was totally retarded in the code department
and couldn't get anything
i got it to work !
YAY !
i got :
11 - crank angle sensor
21 - coolant temp sensor
24 - air control valve
so finally i have some real information to present to
the wonderful people who try to help me out
and it makes things much more obvious
or so i hope
can i assume i need to replace my distributor ?
it just recently got new cap-rotor-wires
in hopes to fix the funniness
only to have it slowly get worse
thanks again for the input
you people are keeping my car alive :}
Coolant temp is easy. Its right on the intake manifold, to the left and closer to the front when looking under the hood. It has one wire going into a epoxy filled plug. There is 2 of them right next to each other. One is the dash gauge, the other is the computer. 5 minute job. I forget which is which. would make the engine run happier knowing it was warmed up. Has it been hard to start?
Crank angle is inside distributor, under rotor. lots of them in J/Y's
starts not bad
runs --alright -- until it warms
than it starts to go haywire
how much for temp sensor ??
from 0-10 bucks.
seriously easy to do.
won't fix all your problems, but its a step in the right direscion. I'd be worried about the crank angle sensor the most, it has the biggest affect on driving.
given the beautiful variety of codes that the computer is spitting out at you, I think that there is a good chance that it is defective itself - a CAS error should/usually results in a "no start" condition - (if you are in a JY, pick up a spare anyway, as they are VERY expensive new or aftermarket - just grab the whole disty body, rotor and cap) - a failing sensor could theoretically cause sporatic engine failures/power loss - at any rate you would find this link useful: http://www.finleyweb.net/default.asp?id=142
the manual is for a 1989 - but most all SPFI systems are identical (save '86 MY)
I would double check the specified sensors with a multimeter following the procedures in the manual before I replace anything - I have had a (two) bad computer(s) throw false codes pointing to sensors when it was the real problem
the sensor is actually the two-wire one below the thermostat housing (closest to the radiator) - the one-wire one is for the dash gague (know from conversion) - not an EASY job, because of where it is tucked, but not too hard either - be sure to bleed the cooling system after replacing it!!!
starts not bad
what do you mean haywire? surging? stalling? backfireing?
Please be aware that the ECU can throw "ghost codes"
It can do this if the engine ever stalls or fails to start.
Recommend you follow the procedure in the
USRM and clear the codes.
Drive and if the CEL illuminates.
Check for the new code asap.
I would change the F.I. coolant thermosensor myself.
It is located below the gooseneck (upper rad hose connection) as 85 Sub says.
It points horizontally toward the pass. side.
Has a wire permanently attached to it.
Is item no. 9 (circled) in the below illustration
They cost more than 10 GWs I'm afraid.
That would be the cost for the dash gauge unit - the wrong one. (Item no. 8 below)
Use an OEM if possible.
The code for the ACV (Air Control Valve) effects the idle.
Hope this helps.
it kind of a missing stuttering kind of feeling
when it starts it doesn't seem to get any better no matter what i do to the gas
i can stop and it will get a bit better
but as soon as i give it gas
it starts up again
along with it comes a clanky noise and a smell
neither of which are there when it first runs
runs ok for the first little bit
seems to do all this when it gets warm
i cleared the codes last night
and started it up again
and got no codes
but it also didn't do anything funny
i will take it for a small drive around the neighborhood when i get home
and see if i can get more codes to come up
i'll post what codes i get later
thanks again for everyones help
