ausubaru92 Posted June 25, 2005 Share Posted June 25, 2005 I my daily course of daydreaming at work i was thinking about the centre diff of a 4wd and realised that wouldn't it be good to have prefect 50 50 split with perfect 100% power to all 4 wheels. I have a soloution! Ever heard of a variable gear ratio, i think its like a cone shaped gear that a second gear slides along to provide variable ratio, and there are tractors that have IVT (infinitely variable transmission) Now my idea is to have this variable ratio in the centre diff that is coupled to the steering, and thus alter the centre ratio to prevent binding on corners ect. but keep 100% of the power to the wheels I know this prob not feesable but its an idea. Gannon Link to comment Share on other sites More sharing options...
stephenw22 Posted June 25, 2005 Share Posted June 25, 2005 don't rally cars have the ability to vary the power distribution, using some cockpit switches or dials? What do they use? Link to comment Share on other sites More sharing options...
MSSLGECKO Posted June 26, 2005 Share Posted June 26, 2005 The WRX STi has a control for the front to rear power ratio if that is what you're thinking of . . . Link to comment Share on other sites More sharing options...
WJM Posted June 26, 2005 Share Posted June 26, 2005 the DCCD-B 05+ STi center diff is about as close as you can get to that. Link to comment Share on other sites More sharing options...
nkx Posted June 26, 2005 Share Posted June 26, 2005 the evo 8s have something similar as well. if you really truely want to split the power so all the wheels had an even share, get lockers. itll drive like a pick up truck though. front and rear LSDs and a 50/50 center diff would probably be as close as you can get without lockers to evenly split up the torque. Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2005 Share Posted June 26, 2005 there is a guy who modified his 4EAT and built his own controller for it. he calls it a paddle shifter so he can adjust the shift points or shift manually. he can dial in power transfer and lock up the transfer clutches as well. some soob manual trans do have 50/50 split to the front and rear. off road, lock the diff. on road, don't lock it. what more do you want from the trans? just a steering sensitive transmission? you could probably use a steering sensor (or a generic sensor/switch) from an XT6 and modify the output to control the locking and unlocking of the center diff if you really wanted to. that would be much easier and cheaper than replacing gears in the transmission. Link to comment Share on other sites More sharing options...
ausubaru92 Posted June 26, 2005 Author Share Posted June 26, 2005 i didnt say it was feesable or even worth the trouble. It was just a theory i came up with while daydreaming the basic idea was a centre transfer that actually changed its ratio proportional to the steering. therefore on a corner, the front drive is spinning faster than the rear (which is what happens in a dif) but instead of the pressure on the drive shaft forcing a differnce of touque in the diff,.. the steering angle will change the actuall gear ratio and provide positive power to 100% of the driveline But nevermind, it was only a thought, never intended to be considered practical:drunk: Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2005 Share Posted June 26, 2005 copy that, daydreamining comment noted on original post. Link to comment Share on other sites More sharing options...
