will this fit?
Does anyonw know if this...
SUBARU LOYALE LEFT HEADLIGHT HEADLAMP 1987-1994
will fit an '88 RX
How much is that costing you? Do you want me to go have a look at the U-Pull? I Could do that on my way if you want me to do your brakes tomarrow???
wow, too much. $14.99 plus $12.66 shipping (seems like a lot to ground ship a headlight) and I would still have the get the turn signal. Don't go out of your way, but if you do go there that would be great.
THats not a bad price to have that lense shipped to you. Junkyard prices might be in the $30-$50 range for a complete composite light.
The bulbs might be alittle costly as well.
-Brian
Hell with junkyards, Thats what USMB members are for.. I have at least one good extra headlight from an 88 wagon in the garage.. not sure which side it is, but I can check.
is it off a wagon or a sedan? the wagon ones are *slightly* different than a 3door or sedan. the glass part is the same, the tub behind it mounts the same, but the top corner towards the grill has a longer tab thats more towards the grill on a wagon lite than a sedan/3door lite. but the tub behid the glass part is swappable, or you can bend things slightly.
its something you wouldnt notice till you went to put it on, if indeed yours was different
judging from the picture it looks like the right one
i could be wrong. the difference could be between 85-86 vs 87 and up, since the grilles were different, now that i think about it. so that means im right again
anyway my point is there is a *slight* difference between some models
The difference is indeed between early and late models. Far as I know they made two different types of lights...
1. 85-86 Sedan and Wagon
2. 87-94 Sedan and Wagon, 86-90 3-door. The 86 3-door takes the same grille as all the other 3-doors, and from what I can tell the lights are the same.
As for the parklamp... you're looking at 87-94 composite headlights only. The 4-headlight setup parklamp is narrower. The 85-86 parklamp will fit, but the reflector is shaped differently.
the only thing you'd have to change is the mounting bracket if it comes with it. They're different between wagons/sedan and 3-doors since the grille mounts different.
