September 15, 200520 yr Hello All! I'm a newbie here and I have a Q. I just got my new 06 Tribeca Limited on Sunday and I LOVE it! The only thing I need (besides an audio upgrade) is to install the trailer hitch... Has anyone installed the thing themselves yet? I'm a bit of a wrenchhead and would like to avoid paying the dealership to do it. So, any tips or info would be greatly appreciated. Thanks! Logan
September 16, 200520 yr Hello All! I'm a newbie here and I have a Q. I just got my new 06 Tribeca Limited on Sunday and I LOVE it! The only thing I need (besides an audio upgrade) is to install the trailer hitch... Has anyone installed the thing themselves yet? I'm a bit of a wrenchhead and would like to avoid paying the dealership to do it. So, any tips or info would be greatly appreciated. Thanks! Logan I am sure you CAN install a hitch if you have mech. knowledge. My question is does SOA have a hitch for the Tribeca? What class is it? Class I, II, III? and is a Tribeca PRE wired for a hitch? What do you want to tow or tote with the hitch?
September 16, 200520 yr if you buy a bolt on hitch then it will bolt on easily. if you get a generic receiver and want to start drilling and welding then you can. easiest to find a made to fit assembly that bolts up. there aren't any for my old school soob so i have to drill and bolt myself. if you can't find a bolt on kit it would probably be best to pay someone else to do it. compared to the cost of the car the cost of this install is miniscule at most.
September 17, 200520 yr logie231, I've installed factory trailer hitches on my 97 OBW and my 02 OBW, and both were a snap. Using standard sockets and tools, I had both hitches installed in an hour, by myself, without needing a hoist, or jacking up the car. Yes, parts of the install were awkward by myself, but no drilling or cutting needed to be done. The only problems I had WITH BOTH KITS was that the instructions said that the new trailer wiring harness just plugged into the car's wiring harness plug, that was in behind the rear interior wheel well panel on one side of the car. When I couldn't find the plugs as described, a quick search of the same location on the other side of the car located them. Must have been a change in specifications from the original by the manufacturer. As I recall, there was some fiddly stuff with a blind nut that was attached to a 3 inch long metal finger. I had to put the nut/finger assembly through a frame hole and hold it until I could put a bolt through another frame hole and thread it into the blind nut. As I recall, I developed a new blue language for about 5 minutes until I held my tongue just right, but that was it. Its a DIYer, if there ever was one. Good luck!
September 17, 200520 yr Hello All! I'm a newbie here and I have a Q. I just got my new 06 Tribeca Limited on Sunday and I LOVE it! The only thing I need (besides an audio upgrade) is to install the trailer hitch... Has anyone installed the thing themselves yet? I'm a bit of a wrenchhead and would like to avoid paying the dealership to do it. So, any tips or info would be greatly appreciated. Thanks! Logan you might consider pricing it from jamie (http://www.subiegal.com) who now works at http://www.subarugenuineparts.com or http://www.etrailer.com may have one. I suspect both will come with instructions for installation. Carl
September 18, 200520 yr Hi list I am new to the list but not new to the Subaru family I have owned 6 forresters, and am now driving a 06 LLBean forrester. Yes SOA sells a hitch for the Tribeca it bolts right on and is wired for one very easy to install yourself.
September 18, 200520 yr I have to throw my typical reply to towing questions in here: If you're going to be towing something of decent heft (I'd say anything over 1000lbs), you might want to consider an auxiliary tranny cooler to keep the tranny fluid temp down. Subaru AT's are very good reliable transmissions... as long as they don't overheat!
