September 19, 200520 yr Is it possible for a distributer (on its way out...jumping tach) to cause a shut off and no start intermittant issue?
September 19, 200520 yr MPFI ones I've seen were vacume advance. Your is electronicly advanced. You need any SPFI one; they are all the same. Let me know if you absolutly can't find one.
September 19, 200520 yr Author I have an MPFI the SPFI is an ongoing isse i have with a friends car, no codes (except for a 5, which seems to be a ghost code no one knows about) replaced fuel pump, and injector, fuel is coming from the throttle body, and computer replaced today but i dont like how she started up, I have noticed the tach jumping on an intermittant basis, im focusing there, but confused as to why no code (and yes the "5" was being issued on both computers) if there was at any point, a disruption in the signal from the sensor.
September 19, 200520 yr I believe "5" means it's a manual transmission ECU, whereas "7" is an automatic transmission ECU. Please correct me if I'm incorrect.
September 20, 200520 yr Author you know thats funny you are the first person to give me a response, my calling subaru to talk to my guys there didnt know, both are leading techs there and thought i was reading it wrong (so offended as I was knowing im NOT insane, i used my treo 650 to video record it !:cool:, the injector was cycling along with the fuel pump, it seems the "new" computer was the fix for at least that, waiting to see its behavior on shutting down, has not done it yet, thanks on the "5" ?
September 20, 200520 yr MPFI ones I've seen were vacume advance. Your is electronicly advanced. You need any SPFI one; they are all the same. Let me know if you absolutly can't find one. It depends on the year. When they switched to the hot wire MAF they also switch to the crank angle distributor
September 20, 200520 yr It depends on the year. When they switched to the hot wire MAF they also switch to the crank angle distributor Yup, I ran an 87 SPFI disty in my 87 MPFI turbowagon for about a year, until it started exhibiting symptoms very similar to what the original poster has going on. I swapped it out for another junkyard SPfi dizzy and haven't had a problem since (well, not a distributor related problem anyway.. plenty of other problems of my own making :-p )
September 20, 200520 yr Author I thank you guys for your help, if I get any more stress from it, ill post a cry for help before i put my head into the fender well to hide....
September 20, 200520 yr plenty of other problems of my own making :-p ) Me thinks many of us would fall into that area..................
