i have a 95 legacy ls awd wagon automatic. when driving with normal acceleration there's no problems, but when i have to step on it to pass it shifts great but i get a big cloud of smoke out the back once it goes over 3200 rpms. any ideas anybody.
thanks steve
i think that can be a sign of ring wear or blow by past the valve stem seals. but i doubt that on this car unless it's been abused.
a full tune up may help - i'd start at a minimum with spark plugs and a new Subaru OEM PCV valve. i'd personally get all new wires, plugs, cap, rotor, air filter....just get a complete tune up and go from there.
That is most definitely not the tranny. I'll bet you'll find it does that with it parked in your driveway.
I second the tuneup stuff. If it keeps doing it after a tuneup, try putting some heavier oil in there, say 10W40 instead, etc. If it does it less, you probably have blowby or valvestem seal issues.
i use 10w40 already and just put in new plugs and wires less than 5,000 miles ago.
all those things were done accept the pcv valve.
Do a pcv valve, and sometimes its normal to have a cloud of smoke come out when you get on it. My 97OBW is doing it , and it seemed to satrt with the relaxing of gas standards. The only thing i can think of otherwise is an 02 sensor, but in all honesty, i would not gte too frantic about it. Try a tank of Ammoco premium and see what happens, or some other brand name good gasoline.
nipper
Hmm. What color is the smoke?
Is it:
  • Gray? -- That indicates your mix is fug-off rich.
  • Blue? -- That's oil burning.
  • White? -- That's coolant unless the exhaust is still cold. Then it could be steam from water condensed in there.
Take that info and add it to this:
Does it smell like:
  • Gas? -- Again, hella-rich mixture.
  • It's acrid, heavy and oily? -- That is, you guessed it, oil!
  • Like burning marshmallows? -- That's coolant.
If the mixture's off, it could be O2 sensors, the ECU, injectors, plugs, wires or possibly a vacuum leak.
If it's oil, you've got ring, valvestem seal or head gasket issues.
If it's coolant, you've pooped a head gasket.
