November 6, 200520 yr ok im trying to arange a trailor to go and get my 95 legacy . now the front axel is broken but not bouncing around . i have about a 20min drive (hiway driving) to get it home . am i goign to wreck stuff if i drive it with the front wheels basicly not working . the tranny and front diff will be working and spinning at speed so i cant see any binding problems but im not sure if it will do damage form the rear getting the 50% for that long . kinda silly question but i cant afford a tow and i might not have a trailer any thoughs thanks
November 6, 200520 yr not a good idea,may cost more than a tow if you make it all the way home,i would beg a trailer somehow.
November 6, 200520 yr I think you will do more damage than the money you'd save on the truck. If its an auto, I don't think it will move at all unless you lock up the broken axle somehow. If its an manual, it may move, but you may damage the diff! If you have no other option, I'd change the axle on the side of the road!
November 6, 200520 yr Author ok thanks guys , when i test drove the car it moved fine (they still dont know its a broken axel ) in fact it wasnt untill the boot popped of was i able to tell it was an axel . but i dotn want to hurt the car at all so ill just have to wait
November 6, 200520 yr Author totally broke just after the outer joint . thanks why the awd wasnt working and when the boot came off it was making nasty noises . so the broken axel spins at the same speed as the rest it just drive off the the rear
November 6, 200520 yr totally broke just after the outer joint . thanks why the awd wasnt working and when the boot came off it was making nasty noises . so the broken axel spins at the same speed as the rest it just drive off the the rear hmm im not sure i understand what the problem is your sure you have a broken axle and the boot hasnt just exploded? can you move the axle up and down outside of the boot?
November 6, 200520 yr Author ok i went to look at this car to buy , they siad it had no awd. upon driving it (i drove normal) but when i turned around on gravel the back tires were slipping and the onts werent doing anything . after i turned around (this is when the boot popped off the axel(hub side) ) the noise it made sounded liek it was time for a tranny . but after checking under the car i could see the axel was just hangin there .(this explains the lack of fwd ) so what i was going to do was cut off the boot on the inner cv and pull the axel out (leaving the splined part in the tranny so the fluid wouldnt leak out )and drive it home
November 6, 200520 yr ok i went to look at this car to buy , they siad it had no awd. upon driving it (i drove normal) but when i turned around on gravel the back tires were slipping and the onts werent doing anything . after i turned around (this is when the boot popped off the axel(hub side) ) the noise it made sounded liek it was time for a tranny . but after checking under the car i could see the axel was just hangin there .(this explains the lack of fwd ) so what i was going to do was cut off the boot on the inner cv and pull the axel out (leaving the splined part in the tranny so the fluid wouldnt leak out )and drive it home your call its what i would do if i didnt have aaa.
November 6, 200520 yr Author got a trailer for tomorrow . dont want to risk it ill post some pics of it tomorrow and see if i got a good deal or not
November 6, 200520 yr got a trailer for tomorrow . dont want to risk it ill post some pics of it tomorrow and see if i got a good deal or not It is a Subaru. You got a good deal.
November 7, 200520 yr (leaving the splined part in the tranny so the fluid wouldnt leak out )and drive it home The way the subaru is design you should be able to just take the axle out without affecting the tranny fluid at all -- the splined shaft stays with the tranny. (unless the AT is designed alot different that the manual) But without real 4wd, trailering it is probably still a good idea. Axles are cheap, but trannies aren't so much....
November 7, 200520 yr Author yea , i took the advice and rounded up a trialer. its home now , however i did just cut the inner boot and pulled the axel out the front (its hard to move it andthe axel might bind up).
